Trek Madone 9 seat cluster
Sabrerider
by Sabrerider
Hi all,
I recently got a Trek Madone 9 SLR. Very happy with the bike but one thing starts freaking me out.
Few days ago I noticed that the whole seat cluster has noticeable lateral play, where it is attached to the frame via the ISO speed hinge. It is not the seat post in the L-shaped part. The whole thing rocks left and right.
I did tighten the hinge bolt a bit already until the wobbling disappeared, but I found no torque values for that bolt. And it made scary sounds, while tightening it.
Has anybody experienced something similar, or found a proper torque value for that bolt?
Thanks for your infos!
Sabre
MitchatTrek
by MitchatTrek
Sabrerider wrote:
Wed Jul 17, 2019 4:55 pm
Hi all,
Sabre
I would bring your bike into your local Trek dealer to have them inspect. It sounds as though it may be overtorqued judging by the sounds it made - overtorquing carbon is risky. But if it was the main pivot bolt under the cover. You tighten the non drive side of it to 8 Nm.
But definitely bring it to your dealer and have them take it apart in that area and inspect the frame.
Community Manager | Trek Bicycle Corporation | www.trekbikes.com
Sabrerider
by Sabrerider
Thanks for the quick answer and the torque value.
I will get it checked up with the dealer.
Sabre
MitchatTrek
by MitchatTrek
Sabrerider wrote:
Fri Jul 19, 2019 7:35 am
Sabre
You're welcome! :beerchug:
jcnz
by jcnz
Yes, exact same thing happened with mine after a few months. 2.5 months later, a new seat setup arrived from trek. Couple of rides in and it's still ok.
The dealer mentioned that trek had seen it before but not often....
Glad the frame has a lifetime warranty because it's awesome ...
Sent from my ALP-L29 using Tapatalk
