3T frame on a Tacx Neo
nogueira.nuno
by nogueira.nuno
Hi Guy,
Did anyone had or have an issue using their 3T frame on Tacx Neo (1)?
I bought the 12x142 tacx adaptor but that doesn’t feel right when assembled both.
If someone have any info I would really appreciated some input.
:beerchug:
moyboy
by moyboy
is your disc caliper hitting on the side? if so use the 5mm spacer.
nogueira.nuno
by nogueira.nuno
That’s true!!
Great tip 👌🏻
ms6073
by ms6073
Tacx's non-drive side adapter is a one-size fits all design. When I purchased it for my Scott Solace disc, even fully tightened, the non-drive side adapter flange did not contact the frames thru-axle fitting so I used a dremel to shorten the adapter. After I replaced the stock thru-axles with Lightning Bolt-On thru-axles from The Robert Axle Project, I noticed the rear was supplied with an alloy bushing.
