Extralite chainring
looking for some chainrings for upcoming build. anyone tried these before and how well do they shift and play with eTap? i see them list a set as 98g, so would be interested to hear some feedbacks.
https://www.starbike.com/en/extralite-o ... set-110mm/
was optimistic that maybe eTap will play well with QXL, but after emailing with SRAM, figured to look for alternatives. plus it'll be lighter than QXL.
A lot of people have complained about shifting performance of Extralite rings on this site. I'm one of the lucky ones! Have used ~4 months combined with eTap and now DuraAce with no issues.
But looking at how many people have had trouble with the shifting I can't confidently recommend them to anyone.
mine have been very good... quick pause is correct. I installed a chain catcher for nothing basically
2024 BMC TeamMachine R Building
2018 BMC TImeMachine Road
2002 Moots Compact-SL- getting aero look makeover
2023 Pivot E-Vault - completed project, full Xplr package
I just installed these a few weeks ago. 102g according to my scale. The set I put on my English more than a year ago came in at 99g. Both are 52/36. Shifting is great. Both bikes running sram red mechanical. No hills here so I go into the big ring and stay there.
Mine was exactly 100g for 52/36
Have these and Quarbon's. No problems with Extralites, but dropped chain three times with Qxl and Di2 because I forgot I wasn't using eTap.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's). Sold.
2016 Rca: 11.07lbs/5.048kg.
2015 Rca. 11.15 lbs(w/Roval CLX 32's)
2015 Rca/NOS(sold).
2018 S-Works SL6 Ultralight 12.03lbs(w/Roval CLX 50's)
2015 Rca/NOS(sold).
Becaue the ramps are made from aluminum they wear. The only way to have worn extralites upshift is with mechanical gears where the fd cage pressure can be held high and long against the high limit.
If only extralite would upgrade the design with titanium pickup pins so that they work reliably with electronic shifting.
Carbon-ti chainrings ought to work better and they are just a few grams more.
i'm a grinder up the hills.. so thought about those carbon chainrings.. but heard they'll fail? which carbon-ti rings would you suggest?alcatraz wrote: ↑Tue Jul 16, 2019 6:01 amBecaue the ramps are made from aluminum they wear. The only way to have worn extralites upshift is with mechanical gears where the fd cage pressure can be held high and long against the high limit.
Let me know how the carborings work out for you. I use 170mm crankarms and usually grind up a 10% hill at 55-60rpm putting out 200-215w or so. I’m also using a 34 small chainring front.alcatraz wrote:Lightweight stuff is more fragile. If you've got tons of torque, maybe on the heavier side, long crank arms, then maybe not use lightweight chainrings.
I'm small so I can get away with it. I was thinking of the carborings 50/34.
I've been advising my ww friend on electronic shifting to try carborings but he hasn't bought them yet. The extralites didn't work.
I'm myself on extralites because I'm still running mechanical shifting. I'm not racing much either so I don't worry about perfect shifting. It works adequately. No dropped chains.
I saw on another thread you were using fibre lytes previously. I guess you prefer the extralites? Is this with etap?
