New Specialized Tarmac 2020
sigma
by sigma
petromyzon wrote:
Mon Jan 27, 2020 9:02 pm
I can't find ANY rim brake Tarmacs, frameset or otherwise, on the UK website.
I picked up one in the US from specialized (heavily discounted pink frame) on the assumption it will be the last one for a while. I will end up getting in repainted to something more my flavor...
S-works Tarmac SL6
S-Works Venge
Factor VAM 02 disc
Trek Domane 2016 SLR
Cervelo C5 2018
Open U.P. gravel 2016
Retired
Cannondale SuperSix Evo Hi Mod 2016 (miss it very much)
Cervelo S3 2015
Cervelo R5 2012
Cervelo S2 2011
bobzz
by bobzz
Can someone ID this part please? dont know what that is for
Came with tarmac s-works frameset
thanks
icantaffordcycling
by icantaffordcycling
The bearing sleeve that sits in between the two bottom bracket bearings?
Hexsense
by Hexsense
eric01 wrote:
Tue Jan 28, 2020 4:40 pm
Specialized will keep them separate with just enough marketing differentiation. Make more money that way.
This, since Tarmac take some of the Venge's aero quantity. Being light and aero.
Venge will gain some other quality. Either even more aero, or added comfort (Madone like?).
Maybe, just different geometry. Tarmac keep traditional short wheelbase for snappy feeling. Then Venge adopt more long low design, more bb drop, extended front center, a touch lower trail value to optimize it for descending/sprinting speed ?
scale29
by scale29
icantaffordcycling wrote:
Tue Jan 28, 2020 6:45 pm
That's exactly what is is, to stop the rear brake hose and gear cable from rubbing on the BB30 axle. if you've switched out for different BB to run say Shimano chainset, you don't need it.
CrankAddictsRich
by CrankAddictsRich
splzd wrote:
Tue Jan 28, 2020 2:26 pm
The SL6 already is not far behind the Venge in terms of drag, with the aforementioned features it will be even closer. It makes no sense to have two bikes in the portfolio with the same aero/drag and the same weight.
You've got it right.... except that gives them new reason to update the Venge in 2021, which is exactly what they'll do.
colagreek
by colagreek
sigma wrote:
Tue Jan 28, 2020 5:48 pm
Just did exactly this, stripped and re-painted by Ron Jones. Simple but stunning when the light hits it.
Karvalo
by Karvalo
ichobi wrote:
Tue Jan 28, 2020 2:51 pm
Pinarello does fine with one superbike. I hope they merge the two.
Fine by the standards of a far smaller company. Specialized sells many more Venges than Pina sells bikes. The Tarmac is on another level entirely.
Karvalo
by Karvalo
Look at the picture above. Seatstays joint with the seattube looks like the Venge. Seatpost ist more aero than SL6. Fully internal cables, add a stem with integration and there's no cable or hose visible at all.
Now look at the downtube, headtube, fork and seattube. It's still not a fully aero bike in appearance like the Venge. No way they're merging two extremely successful product lines.
sigma
by sigma
colagreek wrote:
Thu Jan 30, 2020 4:20 am
Funny, I just sent him my request! Beautiful aesthetic on the bike - very elegant!
S-works Tarmac SL6
S-Works Venge
Factor VAM 02 disc
Cervelo C5 2018
Retired
Cervelo S3 2015
Cervelo R5 2012
Cervelo S2 2011
colagreek
by colagreek
sigma wrote:
Thu Jan 30, 2020 7:26 pm
Ron is the man, good luck with your paint!
Beancouter
by Beancouter
Just been into a Spec dealer in South Africa and he suggested that the venge and tarmac will be collapsed into one model line.
It certainly makes sense given the marginal difference on fully integrated bikes with aero bars / dropped seat stays...
Slack
by Slack
There is only going to be one bike going forward. It's an SL7 tarmac. Lucky enough to have seen it already first hand, obviously I'm not going to post the photos of the bike as the relationships it'll damage are worth more to me. Here's a photo of the box. Enjoy it.
Beancouter
by Beancouter
When is it due to be released?
Beancouter
by Beancouter
Hope they can’t trace the serial number on the box....
