Zipp 202 NSW vs Enve SES 2.2 (clincher/tubeless, rim brakes)
sykkelerik
by sykkelerik
Has anyone in here got any experiene with Zipp 202 NSW and/or Enve SES 2.2 (both clincher/tubeless, rim brakes) and would care to share thoughts?
I am looking for a wheelset purely for climbing (up) steep hills, and while I realize tubulars would save me some more weight, I prefer clinchers/tubeless for ease of use… so between the two mentioned wheel sets, are there any particular pros and cons I should take into consideration?
The wheels will exclusively be used in dry conditions, and mounted on a Canyon Ultimate with DA Di2.
Any and all relevant insights are appreciated.
TobinHatesYou
by TobinHatesYou
The 202 NSW rim brake model is old and fairly narrow. It also isn’t officially tubeless compatible. I’d probably just go with ENVE SES 3.4s tbh.
sgtrobo
by sgtrobo
might want to give consideration to the Stan's Grail CB7
~1300g for about $1600
Very low profile though
TobinHatesYou
by TobinHatesYou
sgtrobo wrote:
Wed Jul 10, 2019 10:02 pm
Those are disc-only.
Noctiluxx
by Noctiluxx
I would go with the tubeless Bontrager XXX 2's, 1305 grams, 21mm internal width, terrific hub, incredible braking, $2400 msrp.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
nemeseri
by nemeseri
I own a pair of Zipp 303 NSWs (2017-2018 non-tubeless version) and it's a great wheelset. The braking is the best I've ever experienced with carbon rims, but still not as good as alloy in wet. I had my first wheel hub bearing replacement after about 15k miles and now I'm about to hit 20k miles with them. Training, racing, touring, commuting and everything in between. Zero problems.
The Ti zipp skewers are great, the pads wear very slowly and the wheelbags are great.
The rear hub sounds pretty weird at first so if you are sensitive to hub noise, it will bother you.
And just like somebody noted before me, the 202 Rim NSWs are not officially tubeless ready.
And I second Noctiluxx that you might also want to check out the bontrager xxx 2s... or maybe roval if you don't mind the subpar braking.
wheelbuilder
by wheelbuilder
xxx 2 is a really nice wheel.
sykkelerik
by sykkelerik
Thanks for all the insight and input! I ended up getting a new bike instead
Johnny Rad
by Johnny Rad
Well-done! For what it's worth, I totally approve of your all-out decision.
Next question is what upgraded wheels are you putting on the new bike?
sykkelerik wrote:
Sun Jan 12, 2020 9:58 am
Thanks for all the insight and input! I ended up getting a new bike instead Image
sykkelerik
by sykkelerik
Johnny Rad wrote:Well-done! For what it's worth, I totally approve of your all-out decision.
Ha ha! The S-Works Tarmac SL6 comes stock with Roval CLX50 wheels that rank well enough weight wise vs alternatives (and handle sufficiently on the road), so I am good for the time being. Looking to save weight elsewhere, and for me, shoes, helmet and clothing is the next frontier!
