Enve 2.0 fork external diameter
Can a kind soul put a caliper around their Enve 2.0 fork? 1/4 to 1/8 taper if they happen to vary depending on steerer. Trying to decide if it will match my frame's headtube decently. And on another topic, these things seem to be the standard for most well regarded custom builders. One obvious reason is the multitude of versions they come in. And the brand fame. But other than this, are they really nice? I am not looking for light and so-so stiff, but truly solid. I am heavy and my current fork seems to flex way too easily when I stand up.
I’m not the biggest fan of enve forks as they look hideous- just take a look at my cherubim. Performance between top end forks is fairly similar so just go with what looks the best. My current favourites are WR FK1 and Pegoretti Falz.
Thanks. That looks great to me but I am not so sensitive to fork shape - as long as it doesn't go to Pinarello levels. My main problem with Enve is the price but I couldn't find an exact match from other makers. I need 1/4 to 1/8 taper and a rake of max 45, ideally 43 which Enve has. I currently have 45 with 73.5 which is a bit twitchy. I imagine a straight 1/8 could work though with some sort of adapter at the bottom but I'd rather not go there if possible. I checked my current fork and it is around 54mm, same for the bottom of the headtube. From the pics I get a feeling the Enve is a bit smaller...
- Similar Topics
- Replies
- Views
- Last post
- 12 Replies
- 1215 Views
Last post by posaunemeister
Thu May 30, 2019 1:51 am
- 0 Replies
- 106 Views
Last post by flmo
Sat Nov 16, 2019 11:49 am
Deda Superleggero RS stem bolt - M5 with a 7 mm head diameter?
by kmanchester » Thu Sep 05, 2019 7:15 pm » in Road - 0 Replies
- 246 Views
Last post by kmanchester
- 1 Replies
- 292 Views
Last post by TobinHatesYou
Wed Jul 10, 2019 5:39 am
- 5 Replies
- 442 Views
Last post by jkonst
Mon Nov 18, 2019 9:55 pm
