Are the wolf tooth water bottle cage bolts the lightest standard bolts to buy?
Geodroid
by Geodroid
Seems so from what I've been finding. They are 1 gram per screw and they are aluminum. I see other titanium bolts are heavier at like 1.5 or 1.2 grams per bolt. What's up with that? So are the wolf tooth bolts the best ones to buy?Image
alcatraz
by alcatraz
Carbon or nylon/delrin bolts are lighter than alloy.
alanyu
by alanyu
J & L alu bolts are lighter, 0.6g
Carbon bolts are even lighter, ~0.4g
burglarboycie
by burglarboycie
Are nylon/plastic bolts strong enough for use with a full 610ml bottle or are they only really suitable for blanking unused bolt holes?
skidrrr
by skidrrr
I'm using J&L bolts and they are ok. Please note they are torx
skidrrr
by skidrrr
== doublepost ==
Geodroid
by Geodroid
skidrrr wrote:
Wed Jul 10, 2019 10:53 am
J&L is torx? Are these they? Did I get lucky and find a hex version?
https://www.ebay.com/itm/J-L-Water-Bott ... 9WdTLGJr3Q
Are these light bolts strong enough? I saw some reviews for the wolf tooth bolts that said htey strip extremely easily when installing and get stuck in the frame :shock:
Geodroid
by Geodroid
Did you make a typo? I can't seem to find any J&L bolts that are torx, they all seem to hex. Maybe it has changed since you last bought them?
skidrrr
by skidrrr
I tried to use hex at first but almost ripped off the thread. Then I realized it's torx
Maybe just my version or maybe they were too soft for hex. At this point I'm not 100% sure
desperado95219
by desperado95219
I've used alloy water bottle bolts and/or carbon exclusively for over 20 years. Only problem has been with the local bike shop mechanics who are used to over torquing bolts. Do it yourself or at least make sure and warn them if they are going to touch. No problem whatsoever in performance or with good mechanics.
10Caad
by 10Caad
No experience with the Wolftooth ones, but currently waiting to hear how much this new option from down in Australia come in at. If anything, they sure are the best looking bolts around.
Wingnut
by Wingnut
Does anyone make hollow bolts, full line bore?
"It's not the destination...it's the ride!"
C36
by C36
Wingnut wrote:Does anyone make hollow bolts, full line bore?
Easily available ?
https://rover.ebay.com/rover/0/0/0?mpre ... 2090242276
That’s titanium. They could optimise with smaller heads. Here they are “big” (mean as per normal iso norms...) J&l offers thinner heads... but that’s only m5...
Thanks 10cad, never heard of them but nice work.
Imaking20
by Imaking20
Does it matter? And I say that as someone who's done some silly sh*t to save weight on bikes. Just curious what the chances are that the combined 1g from all 4 cage bolts will be what keeps you from the weight goal.
With that out of the way, s-works cage bolts are light, reliable and attractive.
Current:
Acid Minty
Boone
Retired:
Wilier Wonka|The Dentist|The Bucket List|Specialissima|Evo|T2|Blue|Project C6.0 | elt AR FRD|Colnago C59|S-Works Tarmac SL4|S-Works Venge| Wilier Cento1 SL|Tarmac SL2
