Lubricating derailleurs and brake pivots
devonbiker
by devonbiker
Hi,
Anyone recommend a good multi purpose oil for lubricating brake caliper pivots, derailleur pivots, jockey wheels, springs etc? I have a few different oils kicking around in the shed but not sure what to use: 3 in 1 multipurpose, muc-off bike protector spray, shimano ptfe lube, mucoff hydrodynamic chain lube, juicelubes wet lube, juice lubes dry lube. I generally wash the drivetrain once every two weeks and commute every day.
I normally just apply muc off hydrodynamic wet lube after I've washed the bike and de-greased the chain and drivetrain then spray muc off bike protector spray (similar to gt40) over the entire bike, with the rims and brake pads covered.
Should I be using something more specialist for derailleurs and brake calipers? Does any part of the rear derailleur need to be greased? I noticed there was some in the spring when the bike was new but this has now all but washed out.
Thanks.
tarmackev
by tarmackev
I do much pretty much the same as you and have been for 30 years. No problems yet.
I'll use whatever lube I have within reason.
The biggest thing I would say is regardless of the lube never let anything get too gunky and black of too dry. Clean and minimal lube as often as needed.
TobinHatesYou
by TobinHatesYou
Basically use whatever you have on hand, but I do prefer something dryish or intermediate...Dumonde Tech Lite or Boeshield T-9 are good standbys.
ghisallo2003
by ghisallo2003
Me too, but I think GFK from Campag has some feedback, particularly on over-sprayed rear mechs with polymer/rubber based pivot points and bushes that degrade when sprayed before being put away for winter. I might be mis-remembering though !
