Anyone have any experience of 2019 Focus Izalco Max disc??
NordicSal
by NordicSal
mrlobber wrote:
Thu Oct 17, 2019 7:50 pm
They look good, but have 62+ mm trail for sizes L and smaller (assuming 25mm tires), and 6mm more BB drop than any other semi-aero bike (which almost all are 70/72mm), so they definitely handle different than majority of other comparable bikes out there.
Now I wouldn't be on the frames concerned, but what does this equate to?
ryanw
by ryanw
NordicSal wrote:
Thu Oct 17, 2019 4:41 pm
ryanw wrote:
Thu Oct 17, 2019 12:59 pm
I've built one from frame up: https://www.instagram.com/p/B136q10neQE ... hare_sheet
58cm
SRAM Red AXS inc. PM
CLX50
7.41kg
Damn it's beautiful. How long is the seatpost, do you happen to know? Wonder if I even fit on the XXL.
I can't remember but in the pic it's 795mm saddle top to BB. There was a fair bit left in the frame for sure.
'16 Cervelo S5 - 6,650g RIP
'17 Focus Mares Force 1 - 7,170g
'19 Cervelo S5 Disc - 7,460g
IG: RhinosWorkshop - Check it out for all my custom builds :thumbup:
:!: Ride Southern Spain Cycling Holidays *£445 for 7 Nights* :!:
wahla21
by wahla21
58cm
CLX50
7.41kg
I tried a XXL the other day and the distance from BB to top of saddle was up at 88cm at one point with a little more to give, so plenty big for most people
Think seatpost is 350mm
Focus Izalco Max
NordicSal
by NordicSal
wahla21 wrote:
Thu Oct 17, 2019 10:07 pm
58cm
CLX50
7.41kg
Nice, then I might be able to squeeze in. I need 91 cm, saddle with high rails would do the trick.
reedplayer
by reedplayer
Hello,
hmmm, Tarmac BB drop 74mm, Trek Domane 80mm..... BB drop seems to be not quite as uniform, and imo does not overly influence handling.
further, steering angles of 70°-72,5° with a fork rake of 46 mm are nothing out of the ordinary as well. Quite similar to, for example, a Pinarello Dogma F12.
if considering different geometries, i find much stranger the long wheelbase of cd supersix evos, size 54->smaller. but, ok, thats another topic.
mrlobber
by mrlobber
reedplayer wrote:
Fri Oct 18, 2019 12:02 am
Hello,
Cannondale, Cervelo, Giant all insist on 57-58mm trail for their Izalco comparable bikes. So does Trek with Madone/Emonda (Domane is not really your semi-aero race bike). Specialized takes things to even more agile side with 55mm on the Tarmac. Scott, BMC, Orbea have around 60mm. Can't tell about Canyon as they don't even list fork rake on their geometry charts, but the Aeroad has 73.5 deg HT for all sizes, so even with 43 rake fork trail is 56mm or less. Mostly the Italians (Pinarello, Colnago, also Wilier) tend to have larger trail values, so Focus joins that crowd.
Nothing bad at this, just a thing to consider as from the looks alone with the dropped seatstays, you'd expect the Focus to be like Teammachine/Evo/Addict.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
