Raising slammed stem
Boshk
by Boshk
How safe/unsafe is this:
Used Colnago bike
Colnago fork expander are usually 3in long
The bike is slammed, so the fork has been cut.
Is it possible to place a 10mm spacer below the stem, get discarded carbon fork tube from LBS, cut 10mm off, place it on top of my fork tube and secure it with expander, stem and cap?
gorkypl
by gorkypl
I would not even consider this as a repote possibility.
Invert the stem or contact your local carbon tech shop to extend the steerer tube.
Klaster_1
by Klaster_1
Maybe flip a 17/20 deg stem? If that's not enough, put riser road bar like S-Works Aerofly on.
eric01
by eric01
A definite no. Don’t risk it. Get a positive rise stem but don’t mess with the fork steere
Bluechip
by Bluechip
If you don't want a high rise stem you could always get a new fork or used one with a longer steerer tube.
alanyu
by alanyu
At least 2/3 of the upper bolt should not exceed the steerer.
TobinHatesYou
by TobinHatesYou
Are you looking to suffer a serious trauma?
ancker
by ancker
Buy a replacement fork with a longer steerer tube.
If you can't or you can't afford to, then don't buy the used bike.
HeluvaSkier
by HeluvaSkier
If you are only looking for 10mm, a zero-degree rise stem will easily get you that much vertical height at the bars (assuming your stem is a modest 6 degrees, at least 100mm and you haven't already flipped it). Easton EA90 with Ti bolts is a nice light option with reasonable aethetics.
If you've flipped your stem already, consider going to a 10 or 12 degree stem... Revisiting highschool trigonometry... I think roughly speaking that for a 100mm stem, every 6 degrees gives about 10mm in bar height change.
alcatraz
by alcatraz
Positive angle stem is choice no 1.
After that maybe look into getting a dropbar shaped like the specialized venge where the clamp area has a low offset.
pdlpsher1
by pdlpsher1
The cheapest way to add stack height is to rotate the bars upward. Not ideal but worth a try and it’s free. Just a tiny bit of rotation will make a big difference.
Boshk
by Boshk
thanks for the advise. Time to look for a 'higher' degree stem.
Wookski
by Wookski
It’s only 10mm, keep riding it and soon enough you’ll get used to the position.
tmchen
by tmchen
Or maybe you can try a raised handlebar?
Bogan
by Bogan
As Klaster commented, Aerofly riser bar.
Sent from my SM-N960F using Tapatalk
MAMIL? Never. O.F.I.L. yeh! (Old F**ker in Lycra)
