“New” 2020 Trek Emonda
ToileySiphon
by ToileySiphon
Wonder if the new fork has more tire clearance. The old one was pretty tight
Envoyé de mon SM-A530W en utilisant Tapatalk
MitchatTrek
by MitchatTrek
ToileySiphon wrote:
Tue Jul 30, 2019 3:34 pm
28mm tire clearance for the Emonda still.
Community Manager | Trek Bicycle Corporation | www.trekbikes.com
Fisherfreerider
by Fisherfreerider
I thought the "max" was always 25c? I run true 28s one mine no problem though.
jfranci3
by jfranci3
The prior unit had zero clearence with a 30c (31mm) tire. 28mm is fine for this bike.
ToileySiphon
by ToileySiphon
Really? Because currently the Trek website lists all the Emonda SL disc 2019 as having clearance for 25mm, while the 2020 are listed at 28mm.
If I'm not mistaken, the fork is shared with the Emonda ALR disc. Here's a picture of mine with 25mm tires (measured at 26mm on the stock rim, 25mm high). You can see that it's already pretty tight in there. I can fit a 5mm hex key, but a 6mm won't pass on the crown and sides. I'd say actual clearance is about 5.5 mm on both sides and the crown.
If I were to put 28mm tires, that would mean an increase in width of 1.5 mm on each side, bringing side clearance to 4mm (which is ok), but the 3mm increase in height would leave me with only 5.5-3=2.5 mm of clearance at the crown, which seems to be way to little and probably explains why the 2019 SL discs are only rated for 25mm.
If you compare with the new fork design (2nd pic, from Trek website), there seems to be way more crown clearance. I'm actually super bummed I didn't get the new design, as I ordered the bike last week - I was really expecting it and now I'm not sure if it's a good idea to stick gp5000 28mm in there. Image
TobinHatesYou
by TobinHatesYou
I’m running 30mm (31mm measured) Corsa Controls on my Emonda SLR and there is room to spare.
