“New” 2020 Trek Emonda
FIJIGabe
by FIJIGabe
Seems like Trek pushed out an update to the Emonda. Internal brake routing through the front fork is all I’ve been able to spot. The Trek website confirms BB90.
It also seems as though they’ve dropped the lower-end S model, and the new “entry level” model is the ALR.
https://www.trekbikes.com/us/en_US/bike ... =red_white
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
nickf
by nickf
I don't see t47 making its was to carbon. No surprise they kept bb90.
Calnago
by Calnago
Yes, kind of agree with you @nickf. As much as I'd like to see a threaded shell (via alloy inserts ala Colnago) in carbon frames, that adds cost and complexity to production, as well as a bit of weight, which would be a huge marketing no no. Maybe wishful thinking that things would return to such a robust and reliable BB design. Fingers crossed however, but I kind of think they will limit T47 to alloy frames for the foreseeable future.
TobinHatesYou
by TobinHatesYou
nickf wrote:
Tue Jun 25, 2019 7:28 pm
No changes were made to the Emonda SLR frame aside from colorway. The 2020 model appeared with the introduction of Red eTap AXS.
You can plainly see the external routing and zip tie on the fork here:
Last edited by TobinHatesYou on Tue Jun 25, 2019 9:28 pm, edited 3 times in total.
Cemicar
by Cemicar
FIJIGabe wrote:
Tue Jun 25, 2019 7:15 pm
I think they've only updated the fork of Emonda SL so far, not the top-level Emonda SLR.
I don't know why not SLR.
TobinHatesYou
by TobinHatesYou
Cemicar wrote:
Tue Jun 25, 2019 8:01 pm
Probably weight. Not sure why T47 is part of this discussion. It's clear the only change to the SL was a fork redesign. If people are really concerned about T47 adding weight to a lightweight frame like the Emonda, they've forgotten about the weight difference between a 24mm steel axle and a 30mm (or 28.99mm) alloy one. It's not a 1:1 exchange, but it keeps everything in the ballpark.
jfranci3
by jfranci3
Looks like the same shoddy routing
MitchatTrek
by MitchatTrek
Hey folks, I've been lurking on here for some time, just wanted to pop in! All Émonda Disc models get this new fork with the new routing and after July 25th, SLR models in Project One will have it. Cheers! :beerchug:
Community Manager | Trek Bicycle Corporation | www.trekbikes.com
jfranci3
by jfranci3
I see now Image
MitchatTrek
by MitchatTrek
jfranci3 wrote:
Tue Jun 25, 2019 9:26 pm
I see now Image
Bingo! Ecpect to see that rolled up to SLRs!
Cemicar
by Cemicar
MitchatTrek wrote:
Tue Jun 25, 2019 9:22 pm
:D This makes me suspect SL and SLR actually shares the same fork...
Note a new set of thru axles is also coming. Maybe not the lightest, but still lighter than the old DT ones to compensate the weight gain of the internal routing?
jfranci3
by jfranci3
The DT Swiss axles were only 20gr heavy. How much does a 6mm hex bit weigh?
moyboy
by moyboy
Nice. Welcome to the forum
MitchatTrek
by MitchatTrek
Cemicar wrote:
Tue Jun 25, 2019 11:08 pm
That's actually been out for a bit! It is the Bontrager Switch axle - uses a 6mm hex to remove and comes with a lever that is friction fitted into it if you want it on (otherwise you remove it and keep it in your jersey pocket when you need to remove the wheel - unless you carry a multitool).
jfranci3
by jfranci3
You’re probably going to have a 6mm hex on you anyway. I wonder why no one has integrated a tire lever into one of these though or out a 6mm hex on a tire tire lever.
