My information was from the exclusive distributor and seller here in January - it depends on, if the frame is on stock - yes = 3-4 months with painting, except frozen colours. Maybe the situation is harder nowadays, high demand...derosa2000 wrote: ↑Sat Mar 27, 2021 10:13 pmV3Rs will be available earliest in September if ordering now , but more realistic is November ...
Colnago V3 RS
- derosa2000
Standard RZ colors in September/November but if you order now , information from Colnagomilanv wrote: ↑Sat Mar 27, 2021 10:44 pmMy information was from the exclusive distributor and seller here in January - it depends on, if the frame is on stock - yes = 3-4 months with painting, except frozen colours. Maybe the situation is harder nowadays, high demand...derosa2000 wrote: ↑Sat Mar 27, 2021 10:13 pmV3Rs will be available earliest in September if ordering now , but more realistic is November ...
Exclusive distributor is only connected to Colnago, so they had the same information confirmed by Colnago...derosa2000 wrote: ↑Sat Mar 27, 2021 11:28 pmStandard RZ colors in September/November but if you order now , information from Colnagomilanv wrote: ↑Sat Mar 27, 2021 10:44 pmMy information was from the exclusive distributor and seller here in January - it depends on, if the frame is on stock - yes = 3-4 months with painting, except frozen colours. Maybe the situation is harder nowadays, high demand...derosa2000 wrote: ↑Sat Mar 27, 2021 10:13 pmV3Rs will be available earliest in September if ordering now , but more realistic is November ...
What they told me in few stores, problems are not frames but parts, all shimano groupsets, disc build equipment, etc..
If i've choose for Derosa for example i can get in 60days Merak, but you never know. You could pay 1/3 of preorder and the wait half of year...
impressive. congrats!stringbean wrote: ↑Tue Nov 24, 2020 3:18 pm1D502179-81AF-4457-933E-0B41158340DF.jpegFE7ED6B2-87E3-434A-BBD4-87CC8C50F703.jpeg
Seatpost arrived,Happy with the build so far.
overall, where did u have the biggest savings weight wise, apart from wheels?
Seatpost?
How is the cable routing with the Schmolke TLO with the default SR9 stem? Does it work well or are there any problems?
If you decide to use different bar/stem on V3RS Disc (using DCR/ACR bars and routing cables via the stem) do you plug the hole above cables between stem and D-shaped steerer with the red plastic plug (supplied with SR9 stem?) if so, do you shorten it so it fits the stack height of the stem? Thank you!
Nobody used different stem than SR9? I have heard different oppinions on this..some people say that without the red plastic plug the stem will not hold properly and can rotate, some people say that it´s not neccessary there..i would also like to know how would you feel about safety of the solution if the red piece sits opposite the upper stem bolt but don´t cover the lower stem bolt (obviously because there are cables...)hannawald wrote: ↑Sat Apr 03, 2021 9:03 pmIf you decide to use different bar/stem on V3RS Disc (using DCR/ACR bars and routing cables via the stem) do you plug the hole above cables between stem and D-shaped steerer with the red plastic plug (supplied with SR9 stem?) if so, do you shorten it so it fits the stack height of the stem? Thank you!
Thank you so much for your oppinions..
- wheelsONfire
The bottom half can probably be put backwards and then you have same range as usual
Bikes:
Open *UP* (2016.04.14)
Higher stack to reach ratio, something preventing me from getting bikes such as SL7. I need a 555-575 stack for a reach of 377-385 max and aim for a 619/625 and 470 on the handlebar. In essence being of italian descent, i have longer legs and a smaller torso- we are talking just 2-3 cms here, and the difference on being a good runner, soccer player etc. this goes back to the roman legions and the marching or running requirements. anyhow, it pains me but, for example, i cannot do that 540/385-390 frame first all bikes have the 30 mm spacers, if someone puts me in a more aero i have to bend abnormally the back to stay in position, or, on drops, my knees almost touch my chest. as an amateur unlicensed rider I wondered how did i do that first fondo position or top 20 strava score on an endurance non aero bike, 42-43km/hr over 10 k? shorter torso, less drag, bigger pistons, legs and stroke.
Germanic, anglo saxon groups, including gallic, have shorter legs and larger torso. again, we are talking here 1-3 cm variance (and arm length) but enough to change the geometry requirements. that means they need a longer reach and deeper aero to compensate for the giant air brake we call upper body.
now i need a new bike and the onky ones compatible are Colnago, Look, Time, Willier Pinarello, custom Lampo, to provide a stack to reach ratio of 1:44 or higher. when we look at these numbers, we are talking a more compact frameset, higher stack (by 20-30mm), and generally engineered for more comfort. Generally. BTW Basso realized that they were having issues selling top frames to non pros so they added the missing higher stack to reach ratios as of 2021.
The store I do social media for got 3 V3Rs framesets and two Colnago gravel bikes over the last month (in Switzerland).
