Colnago V3 RS
after one week
today I just pick up the frame.
So it is very good job the finish, not expensive, only 100usd. It is worth it!!!
So Colnago afterservice is sucks, you can send to the original factory for repairment, even if I want to pay for any cost!!!
and then, my friend have a team and recommend a very good studio to repair this
check the picture
check the picture
Also it's a Colnago. You don't even need the geo chart because seattube length = frame size. He's asking about a 42s, the seattube length is 42cm.
Wow!! That one really looks nice!! Is that a zero offset seatpost?wickedstealthy wrote: βThu Apr 28, 2022 7:56 pmAlmost finished.
Weight including bottle cages, Garmin mount and pedals
Likely 6.5kg final weight without Garmin mount and cut seatpost and lowered handlebar (further cut steerer).
Hope that darimo one day brings out a 0mm seatpost without loops like the factor ostro version
who did the repair ?extrusionedwin wrote: βSat Apr 16, 2022 2:55 pmafter one week
check the picture
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2022 Ridley Kanzo Adv Rival/GX AXS-Zipp 303s
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2022 Basso Palta 2-Rival/GX AXS-Zipp 303s
2023 Colnagno G3X-SRAM Force-Levante
local specialist of carbon frames studio. third party
Yup it's the Colnago straight post. I have it matte black painted and removed the logo.pmprego wrote: βMon May 02, 2022 12:51 pmWow!! That one really looks nice!! Is that a zero offset seatpost?wickedstealthy wrote: βThu Apr 28, 2022 7:56 pmAlmost finished.
Be aware that you need to order other clamps as Colnago only delivers clamps for round rails. But if you are interested I can direct you to the correct ones from Ritchey Logic which fit. I believe the clamps used on Willier also works
Looks nice! If you use the Bonti RSL bar and Galfer rotors, maybe you'll be scratching at 6kg soon.wickedstealthy wrote: βThu Apr 28, 2022 7:56 pmAlmost finished.
There are some things I could consider but I like the farsport bars. Short reach longer stem and they are stiff. The seatpost is something that I would consider from darimo but not if they keep the loops or triangles. Purely from an aesthetic point of view I don't like them. Same for their bar. Not my cup of tea in current incarnation aesthetics wise.BigBoyND wrote: βWed May 04, 2022 7:15 amLooks nice! If you use the Bonti RSL bar and Galfer rotors, maybe you'll be scratching at 6kg soon.wickedstealthy wrote: βThu Apr 28, 2022 7:56 pmAlmost finished.
If selle would release a flite boost saddle like the selle slr dalara I would consider that too.
Lower heights wheels also gave me more savings. Or using super spokes...
I should have bought a non frozen paint if weight would have been the goal
The thing ride as a charm and that's good enough. And lots of the above mentioned stuff is compromising reliability or for me aesthetics wise
Fun thing is that this bike rides smoother and is more compliant then my Canyon Endurace which is geared more to long rides
I switched back in the weekend and found it suddenly harsh
So I have mounted this hanger from Frames and Gear and it works great.
https://framesandgear.com/shop/direct-h ... ur-hanger/
