Lightweight 36cm (c-to-c) handlebars
octave
by octave
hi everyone,
i am looking to build a light bike for my sister. she needs 36cm c-to-c handlebars.... the only lightweight option i am aware of are the S-Works carbon bars. are there any other options? ideally under 200 grams.
thanks!
o
moyboy
by moyboy
c-c at the hoods is 36cm for the FSA SL-K compact handlebars.
Should be 180 grams or so.
My wife is in the same boat.
Cemicar
by Cemicar
Although replaced by Superergo, 3T Ergonova/Ernova 380mm was actually around 360mm. The LTD one was sub-160 grams.
octave
by octave
thanks for the suggestions! the 3t LTD bar at 160 grams would be pretty great...
alanyu
by alanyu
Cemicar wrote:
Fri Jun 21, 2019 4:12 pm
That's not correct. They have changed the measurement method on their website. Now they measure and mark hoods c-c on new superergo instead of drops c-c on old ergonova, resulting in 380 is actually 380 c-c on hoods while 400 c-c on drops for superergo. I've also confirmed this from a local retailer.
Besides, s-works shallow 36cm is actually 34.5 c-c on hoods, around 170g, while 38cm is actually 36.5 around 180g
Cemicar
by Cemicar
alanyu wrote:
Sat Jun 22, 2019 9:27 am
I was explicitly talking Ergonova/Ernova. 3T was selling Ergonova/Ernova with the width measured between drops, and that's why they were narrower at hoods. Superergo is a successor and as you say uses a different measurements.
Ergonova 380: 360 (hood) 380 (drop)
Superergo 380: 380 (hood) 400 (drop).
I do own Ergnova 380 and it's certainly around 360 between hoods.
JerryLook
by JerryLook
+1 on the Ergonova measurements. My 38cm Ergonova are 36.5cm C-C at the hoods and 38cm at the drops.
The Ergonova Team I have now are right at 200g and the 38cm Ergonova LTD I had before were right at 180g.
The only Ergonova I have seen that we’re close to 160g were sanded down to carbon, but I’m sure there is some variation between batches.
2010 Orbea Opal 54cm
5.97kg
