What would be your ultimate disc road bike build.
MichaelB
by MichaelB
double post :roll:
flick10
by flick10
Hi Guys;
I'm new to this forum and have just built a Pinerello 10 Disc which came out at 7.25Kg - is this good?
Spec 53 cm frame
Full Axs red 12 speed etap group 47/35 crankset, 33 / 10 cassette, 140mm discs, and blip remote gear buttons
Wheels zipp 303 shod with schwalbe pro 1 28mm with tubes
speedplay zero pedals with full J&L Ti upgrade kit - cost about £50
Deda stem and bars & tape - the most bars and stem look great but weigh a ton
2 x Bontrager XXX bottle cages
Carbon garmin mount
Thats about it
morrisond
by morrisond
MichaelB wrote:
Thu Jul 25, 2019 12:59 am
morrisond wrote:
Wed Jul 24, 2019 2:23 pm
MichaelB wrote:
Wed Jul 24, 2019 11:31 am
A custom Llewellyn Colussus disc.
Couldn’t afford one, but do list after one and his craftsmanship is top class
I lusted after that bike as well. The cost was a little out of what I wanted to spend so I did this instead which uses the same size tubing he does (and stiffer chain stays) but fillet brazed.
Looks sweet. How does it ride ?
What was the cost of the frame ?
Sorry for the late response.
It rides great - but not as good as my Warbird with 38mm Compass Tires - but nothing does. If I did it again I would probably do the same tubing with the ENVE Gravel fork to take the Compass 38's.
Only about $2,300 USD if I recall correctly. But then I spent a fortune on Paint by Velocolour. Matt at Saltair will get it painted for you for not much more than the $2,300 by Spectrum I think which do pretty good paint.
Restyle
by Restyle
For me this one, ordered it last week, let the waiting begin :(((
FEATURES
Modell/Model Ridley Noah Fast Disc
Rahmen/Frame Noah Fast Disc, 60T-40T-30T High Modulus Unidirectional Carbon, In-Mould F-Surface Technology, TA 12x142mm
Gabel/Fork Noah Fast Disc, 60T-40T-30T High Modulus Unidirectional Carbon, In-Mould F-Surface Technology, TA 12x100mm
Dämpfer/Rear Shock -
Federweg hinten/Travel r. -
Steuersatz/Headset Ridley
Vorbau/Stem Ridley Fast Integrated Cockpit
Lenker/Bar Ridley Fast Integrated Cockpit
Vorderradbremse/Brake f. Sram Red Disc Flat mount
Hinterradbremse/Brake r. Sram Red Disc Flat mount
Bremshebel/Brakelever Sram Red eTap AXS Disc
Umwerfer/Front Derailleur Sram Red eTap AXS 2x12
Schaltwerk/Rear Derailleur Sram Red eTap AXS 2x12
Schalthebel/Shifter Sram Red eTap AXS 2x12
Kassette/Cassette Sram Red XG 1290 12-Speed
Kette/Chain Sram Red AXS
Kurbel/Crankset SRAM Red AXS 2x12
Innenlager/BB Sram PF DUB
Pedale/Pedals -
Vorderrad/Front Wheel DT Swiss ARC 1400 Spline Disc 62
Hinterrad/Rear Wheel DT Swiss ARC 1400 Spline Disc 65
Reifen vorne/Front Tyre Continental GP 5000 Tl
Reifen hinten/Rear Tyre Continental GP 5000 Tl
Sattelstütze/Seatpost Ridley Fast Noah Carbon
Sattel/Saddle Fizik Arione
cunn1n9
by cunn1n9
Restyle wrote:For me this one, ordered it last week, let the waiting begin :(((
FEATURES
Pedale/Pedals -
The lines of this bike to my eye are ruined by the rear wheel cutout. It’s kind of a halfway house. I prefer either a full version like the Canyon Aeroad or S5 or just a normal seat tube. This looks wrong to my eye. Same problem with the Basso Diamante SV. Prefer the non SV for the same reason. It’s probably only worth 1 watt anyway.
