Basic pressfit tools..... Risky?
Boshk
by Boshk
Bike is bb86.
Debating on buying a pressfit tool from Chainreaction cycle, basically around 50bucks to install campy UT cups and (sram GXP on 2nd bike)
Will they work or do I stand a high chance of making a mess of it?
Colnago C60
Miller
by Miller
It'll work. Just take it carefully and make sure the cups are going in straight.
addictR1
by addictR1
i have the same BB86 and just went to hardware store to pick up a long bolt, washers and nuts. then it just slides right in. but like Miller suggested, do it slowly to make sure it goes in evenly.
hambini
by hambini
Studbar and two nuts will do the same job. £3 from ebay.
Hambini Aeronautical Engineer, Ex NASA, ex Lockheed - views expressed are my own...
Add me ON TWITTER!
Hambini SRAM Dub Bottom brackets Coming Soon!
Visit the Hambini Website
4ibanez
by 4ibanez
hambini wrote:
Wed Jun 12, 2019 8:55 pm
Just write "Park Tools" in marker pen and job's a good un!
I pressed in a PF30 a couple of times using a DIY press. Same for the removal tool!
ancker
by ancker
I've used a DIY press several times.
The trick to doing it right is to do one cup at a time. Took me a few BBs to figure this out (I didn't break anything, just took 10x longer as I couldn't get both to stay straight at the same time.)
That said, the last BB I installed was a thread-together type that worked in PF frames. It was _super_ easy.
Mr.Gib
by Mr.Gib
FYI Wheels Manufacturing sells a very affordable press complete with all the drifts you'd ever need. Once you get the hang of pressing and removing bb's and other bearings which takes about a minute, it's a breeze.
wilwil
by wilwil
Mr.Gib wrote:
Wed Jun 12, 2019 10:20 pm
As above.
Boshk
by Boshk
Just had a look, that Universal Pressfit tool, that’s very affordable and looks like great option.
Just need a removal tool too then I’m pretty much set to DIY everything.
Colnago C60
bremerradkurier
by bremerradkurier
Boshk wrote:
Thu Jun 13, 2019 2:35 am
Park's BB-86 remover happens to come with drifts for Shimano BB cups.
flying
by flying
Yes I also have that Wheels Bearing Press as you said inexpensive & works great
https://bicyclepartsdirect.com/economy- ... press.html
I also bought these universal drifts & it takes care of everything I need
https://bicyclepartsdirect.com/universa ... drift.html
Alpine318is
by Alpine318is
I've used this guy in 15+ frames with no issues.
https://wheelsmfg.com/presses-tools/uni ... press.html
2012 Specialized Venge S-Works
eTap
ENVE 4.5
2013 BMC Granfondo GF01
eTap
ENVE Classics 45
2016 Cervelo P2
Ultegra 6800
ENVE 6.7
reknop
by reknop
The pressing part isn't the tough part. The cheap versions will do fine there.
Removing the old cups and bearings with controlled force on your carbon frame is something different. I prefer the CEMA Bearing Bottom Bracket Replacement Tool, which is very similar to the Enduro bearings.
https://www.remo-knops.com/5420/cema-be ... cket-tool/
Sent from my Nokia 8 Sirocco using Tapatalk
https://www.remo-knops.com/cycling/
