Scott Addict Disc 2020
Same one that i ordered with my addict, apparently the bike shop ordered a pair so i'll ask them if it's available as i'm picking my bike up sometime this week
This is My Ride Perth Central so you can give them a ring to ask too
Also for those looking for the syncros mount for the creston IC SL, My Ride cannington has 2 more in stock, i've picked mine up on Tuesday
Thanks Signal
=== update===
Spoke to My Ride Perth Central. Apparently the "pair" (as in one set, not two sets) they ordered was for Signal's bike so they're out of stock. The distributor in Australia won't have stock until late August at the earliest. Seems they're pretty much out of stock worldwide
=== update===
Bummer! Covid has really delayed alot of stuffs unfortunatelyGeoffS wrote: ↑Wed Apr 28, 2021 12:32 pmThanks Signal
=== update===
- protocol_droid
I have a 40x100 ic sl brand new.GeoffS wrote:If anyone has a set of Creston IC SL bars in 400mm width, 90mm stem that they'd consider selling, please let me know.
Sent from my SM-G991U using Tapatalk
naked 3po, the first weight weenie.
Looking for a bit of help. I've managed to scratch my Scott Addict RC 30 (in prism green/purple matte color) in a couple of places (chainstay from shoe rubbing against it, seat tube is the other place). I am quite careful with my bike, but this matte finish seems to be very prone to scratches. Here are the scratches on the seat tube:
From my limited knowledge about matte finishes, there's no buffing it out. What are my other options to make them at least less visible, if not completely getting rid of them? The scratches are not overly obvious, but they do bug the hell out of me (bike is couple of months old). OCD is kicking in hard.
- protocol_droid
You could just fill it with clear nail polish and that would help minimize the glare of the "white" edges.
Long story short, i've got a brand new Syncros comp mount for creston IC SL (packaging opened but not used)
https://www.syncros.com/au/en/product/s ... l-bar-stem
Anyone interested?
Anyone interested?
Thanks for everyones contributions in this thread. It's been really helpful in building up my bike. I've just one more thing left to buy. Can anyone confirm for me what bolts I need for fitting Dura Ace R9170 disc calipers on to a 2020 Ultimate RC team edition frame please?
Am I right in thinking it's one of these;
https://www.sjscycles.co.uk/brakes/shim ... y8n208030/
and three of these;
https://www.sjscycles.co.uk/brakes/shim ... y8n208040/
If not, where can I find the correct ones?
Thanks again for the help.
and three of these;
It depends on rotor size, viewtopic.php?t=152493gdf wrote: ↑Sun May 02, 2021 8:17 pmThanks for everyones contributions in this thread. It's been really helpful in building up my bike. I've just one more thing left to buy. Can anyone confirm for me what bolts I need for fitting Dura Ace R9170 disc calipers on to a 2020 Ultimate RC team edition frame please?
and three of these;
FALSE. In case of flat mount brakes, bigger rotor is accomodated via caliper adapter, on which caliper is offset with a separate set of bolts (so that 2+2 bolts go through the adapter). If the caliper adapter would be used just as a shim (as your post would suggest), then the pads would not fully face the rotor.
Ironically, the post you quoted says nothing about how it depends on rotor size.
Yes, those are correct.gdf wrote: ↑Sun May 02, 2021 8:17 pmThanks for everyones contributions in this thread. It's been really helpful in building up my bike. I've just one more thing left to buy. Can anyone confirm for me what bolts I need for fitting Dura Ace R9170 disc calipers on to a 2020 Ultimate RC team edition frame please?
and three of these;
Enid: Scott Addict RC Ultimate Team Ed - 7.2 kg (in. pedals and bottle cages)
You Sir appear to have no idea of Irony, were you instructed by Alanis Morissette? I merely posted a link to how you can measure which length bolts are suggested by Shimano.ddddd1 wrote: ↑Sun May 02, 2021 10:20 pmFALSE. In case of flat mount brakes, bigger rotor is accomodated via caliper adapter, on which caliper is offset with a separate set of bolts (so that 2+2 bolts go through the adapter). If the caliper adapter would be used just as a shim (as your post would suggest), then the pads would not fully face the rotor.
and three of these;
https://si.shimano.com/pdfs/dm/DM-RADBR01-03-ENG.pdf
https://www.youtube.com/watch?v=8OJXFA1fLSM
If you fit a larger 160mm rear disc the kit comes with two spacers which are not necessary if shorter bolts are used. And if you are not substituting standard steel bolts for titanium should you even be posting on weightweenies? I bid you a good day.
Just confirming more or less what everyone is saying. Yes, the bolts you've suggested are correct.
As standard, the Addict comes with 160mm rotors front and rear.
At the rear, the caliper is fitted with an adapter plate, and the bolts actually thread into this. The same bolts also come with two thick washers under the heads of the bolts.
If you swap for a 140mm rotor at the rear, you remove both the adapter plate and the thick washers, and the same bolts thread directly into the caliper. Pics below show my bike before and after swapping to 140mm rotors.
Ah, sorry. The amount of idiocy I've seen on the internet (and many times I thought it's just irony, oftentimes it turned out it wasn't) prevents me from recognizing irony.mikemelbrooks wrote: ↑Sun May 02, 2021 11:25 pmYou Sir appear to have no idea of Irony, were you instructed by Alanis Morissette? I merely posted a link to how you can measure which length bolts are suggested by Shimano.
However, should you be posting on weighweenies, if you don't fit rotor that is as small as possible?
Where are you located + price?nodivision wrote: ↑Mon Apr 26, 2021 5:00 pmI got my new iC bars in last week after ordering in Jan. 40cm and a bit shorter stem. Can't wait to have fit dialed in! If anyone want the 42cm 110mm after I swap them out let me know!
