The steerer is 1 1/4", as is the cockpit. Are you sure it fits?
Scott Addict Disc 2020
Stem angle is -6 deg. Distance between bolts is 15mm.
Not sure what width you are looking for?
Thanks,
I am looking for actual external width of the stem/Spacers.
This probably won't affect if it fits mechanically, but if it is going to look nice.
-6 degrees is promising.
A reduction sleeve from 1 1/4 to 1 1/8 is no problem:)
Interested in buying Carbonsport Lightweight wheels with broken spokes.
BMC Teammachine SLR01 Disc Team 2018|Ridley Helium | Kuota Kross|Cannondale Scalpel 29 Hi-Mod
Thanks for this very helpful information
Will come back to you, if I need a STP File
For anyone who has made the switch from standard two piece Creston bars/stem to IC SL, did you have to buy the SL spacer kit separately or did it come packaged with the bars?GeoffS wrote: ↑Wed Feb 17, 2021 4:01 amThere is an (fairly brief) Addict RC manual on the Scott website but it is a little difficult to find. Relevant sections from it are shown below.
The metal spacers are only used if you want to experiment with setting the height of the stem before cutting the steerer tube to length. Earlier in this thread somewhere there are some photos.
You can't change the angle of the bar.
And I guess the IC spacers are not suitable at all with the one piece system?
Cheers
Spacers are included with the iC SL bars.BianchiDave wrote: ↑Wed May 12, 2021 7:38 amFor anyone who has made the switch from standard two piece Creston bars/stem to IC SL, did you have to buy the SL spacer kit separately or did it come packaged with the bars?
Correct. They are a different profile (viewed from the side) around the front removable part.BianchiDave wrote: ↑Wed May 12, 2021 7:38 amAnd I guess the IC spacers are not suitable at all with the one piece system?
thats great, thanks GeoffGeoffS wrote: ↑Wed May 12, 2021 8:55 amSpacers are included with the iC SL bars.BianchiDave wrote: ↑Wed May 12, 2021 7:38 amFor anyone who has made the switch from standard two piece Creston bars/stem to IC SL, did you have to buy the SL spacer kit separately or did it come packaged with the bars?
Below is the reply I had from Scott on the seatpost screw for my 2020 frame:
'Good Afternoon
Thank you for reaching out to us regarding your Addict RC seat clamp.
The Spec of the grub screw is M6 x 0.75mm thread pitch with a flat head.
We have managed to find a replacement grub screw for you which we will send out to the address in your signature, we have also attached the instructions of how to set this clamp up.
Kind Regards
Your Scott Sports Team'
I also bought some from these guys below in the UK but never had to try them out because Scott found me a replacement. You could give them a try they were very helpful on the phone.
https://simplybearings.co.uk/shop/
'Good Afternoon
Kind Regards
Nice build and bike!SiGNAL wrote: ↑Thu May 13, 2021 4:07 amPXL_20210430_090526497.jpg
Happy snaps of my custom addict rc, currently weighing at 7.34kg with pedals,mounts and cages with the 60mm wheels
Have ordered and awaiting delivery of 45mm wheels and hoping to get it under 7kg
Happy with the Cermaicspeed pulley ?
(also consider this)
