Not 100% match, but still close. I doube you'd find identical colorRoadbiker10 wrote: ↑Tue Jun 21, 2022 6:29 pmIt doesn't look the same to me. Isn't the RC 10 matte silver?
Scott Addict Disc 2020
His: Orbea Orca OMX
I also want to warn people that the rails can be in completely different positions on saddles. I had my 20mm setback post on sale until I got a Power Mirror saddle. With that saddle I had to revert to the 20mm post for it to be in the same position behind the bb-c. So with my Fizik Argo, on a 5mm post, it's furthest forward on the rails. While with the Power on a 20mm post, it's in the middle of the rails.
I have carefully measured so that the position would be the same. Measured between bb-center to saddle tip and factored in that the Fizik is 265mm and the Power I think was 243mm.
So now I have to keep both post just in case I ever want to change the saddle.
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
Yeah I know, I just think it would be a nice color. I don't really like the new colorways much, the black ones and the greens for example.TLN wrote: ↑Tue Jun 21, 2022 6:41 pmNot 100% match, but still close. I doube you'd find identical colorRoadbiker10 wrote: ↑Tue Jun 21, 2022 6:29 pmIt doesn't look the same to me. Isn't the RC 10 matte silver?
Anyone know when will Scott release the 2023 colours?
That headset adapter looks super clean, have you had any issues at all with it so far? I've got the 2020 RC30 with mech ultegra and something like this seems to be the only way to avoid a 2 hour stem swap (apart from a Di2 upgrade, which is out of stock and way pricier)
Just works. I have Campa rotors on my GRX and works just as good as the Shimano rotors
Hi all,
Is my first post on this forum and i will present myself. I'm portuguese and a occasional rider, my main sport is trail running.
I read almost all comments of this thread and heard situations similar to mine, but I didn't find any solution.
So, my bike is a Scott Addict RC size 49 with a Creston IC handlebar (stem integrated) 420mm x 100mm with all cables inside.
I'm 162 cm and my bike is right size for my leg measure, but is too extended.
I did a bike fit and need 20mm less than i have now, 80mm stem i guess, but Scott only have from 90mm. Do you know any other brand or system to adapt? Or i need to sell this frame?
Normal Scott stem (100mm) and a normal handlebar is more short than Creston IC (100mm) integrated system?
Could Scott RR IC stem (90mm) works on my case?
Really thanks.
Really thanks.
Hi, the addict rc can use the new gravel speedster headsets. With that you can use a 90mm stem from syncros (or in theory any stem) and switch to a shorter reach handlebar (the creston ic has a 75mm reach and you can find handlebars with 65-70mm reach "easily").joaoalves wrote: ↑Wed Jun 22, 2022 3:38 pmHi all,
Really thanks.
No issues, so far so good. However it would probably not work with your mechanical groupset due to a tight radius of the cables under the stem and the hole for cables is big just enough for only 2 hydraulic hoses and Di2 cable.vanitypl wrote: ↑Wed Jun 22, 2022 2:01 pmThat headset adapter looks super clean, have you had any issues at all with it so far? I've got the 2020 RC30 with mech ultegra and something like this seems to be the only way to avoid a 2 hour stem swap (apart from a Di2 upgrade, which is out of stock and way pricier)
Enid: Scott Addict RC Ultimate Team Ed - 7.2 kg (in. pedals and bottle cages)
Bummer... makes sense that you optimized it for electronic though. Do you think it would work if I tried (or got one of my smarter friends to try) making a version with a bigger hole? Or is the limitation in the actual space in front of the steerer? It's been a while since I've opened it up so I'm foggy on the internals at the momentddddd1 wrote: ↑Wed Jun 22, 2022 9:08 pmNo issues, so far so good. However it would probably not work with your mechanical groupset due to a tight radius of the cables under the stem and the hole for cables is big just enough for only 2 hydraulic hoses and Di2 cable.vanitypl wrote: ↑Wed Jun 22, 2022 2:01 pmThat headset adapter looks super clean, have you had any issues at all with it so far? I've got the 2020 RC30 with mech ultegra and something like this seems to be the only way to avoid a 2 hour stem swap (apart from a Di2 upgrade, which is out of stock and way pricier)
Thanks.pmprego wrote: ↑Wed Jun 22, 2022 5:00 pmHi, the addict rc can use the new gravel speedster headsets. With that you can use a 90mm stem from syncros (or in theory any stem) and switch to a shorter reach handlebar (the creston ic has a 75mm reach and you can find handlebars with 65-70mm reach "easily").joaoalves wrote: ↑Wed Jun 22, 2022 3:38 pmHi all,
Really thanks.
Could you give me some models?
Syncros RR 2.0 could work?
the rr2.0 works. specialized has a 65mm reach handlebar but you have several 70mm reach bars (I like zipp's the best).joaoalves wrote: ↑Thu Jun 23, 2022 12:35 pmThanks.pmprego wrote: ↑Wed Jun 22, 2022 5:00 pmHi, the addict rc can use the new gravel speedster headsets. With that you can use a 90mm stem from syncros (or in theory any stem) and switch to a shorter reach handlebar (the creston ic has a 75mm reach and you can find handlebars with 65-70mm reach "easily").joaoalves wrote: ↑Wed Jun 22, 2022 3:38 pmHi all,
Really thanks.
I can only speak for my product, but I tried some other models with thinner walls and they usually cracked after a while of using. This thickness is as little as I am confident with.vanitypl wrote: ↑Wed Jun 22, 2022 10:13 pmBummer... makes sense that you optimized it for electronic though. Do you think it would work if I tried (or got one of my smarter friends to try) making a version with a bigger hole? Or is the limitation in the actual space in front of the steerer? It's been a while since I've opened it up so I'm foggy on the internals at the moment
Actual space in front of the steerer is naturally not a limit, since normal Syncros stem uses the same headset internals as I am and theirs should be working with mechanicals as well. If you were to use something similar to mine, you would still have to deal with that cable radius, which would mean that the cables would have to be all over the stem, which I think wouldn't look too good, but it's all about preferences.
Any thoughts or information to share about that setup? Are 303 FCs any good?pmprego wrote: ↑Sun Jun 19, 2022 7:51 amUsing those. I had/have some 28c tires blowing up to close to 31.5mm and they are OK. A 30c tire growing up to 33mm for instance I guess it would be a problem.Ytse wrote: ↑Sun Jun 19, 2022 6:38 amTeam,
I have an Addict RC (2020 model) with Campagnolo Bora WTO 60 wheels and Continental GP5000 TL tyres (25mm). I plan to go wider and would like to know if 28mm tyres on a Zipp 303 Firecrest (30mm external width) will fit the frame. Do you have any first hand experience?
2020 Scott Addict RC / 2021 Trek Emonda SLR / 2023 Specialized Tarmac SL8
