The seatpost is included in the picture and on the "frameset package" but the reported weight cannot include it. Frame (850) and fork (360) alone are 1210gr. Then you have seatpost (140) seat clamp (12) through-axle (unknown). A good reference point is the canyon slx ultimate frame. 1800gr with handlebar included. I imagine that the addict can be a few grams less WITH the IC SL cockpit careful.g32ecs wrote: ↑Wed Nov 06, 2019 2:16 pmSeat post is included in the frameset modulepmprego wrote: ↑Wed Nov 06, 2019 4:40 amIt seems too optimistic. Yates brothers had their tour and vuelta rc pro bikes weighted and were around that number and they were using Dura-Ace which is some 500gr less than force etap. Thus, you are missing some half a kilo in there.g32ecs wrote: ↑Wed Nov 06, 2019 12:41 amThat's awesome!
I'm trying to estimate a build here so correct me if I'm wrong:
XXS RC Pro frameset - 1200g
Creston handlebar - 300g
Force eTap - 3000g
According to here :
https://bikerumor.com/2019/06/10/hands- ... oad-group/
Wheelset (my own) - 1500g
Tubeless tires (my own) - 450g
Saddle (my own) - 180g
Cages x2 (my own) - 30g
Pedals (my own) - 165g
My total so far is 6825. All that's variable is sealant, handlebar tape, garmin mount...am I missing anything else?
I've been very generous with the weights, so a 15lb bike is achievable (?) Not that it matters to me, but my goal is to go lightest with my budget (so far the groupset is non-negotiable, but I can cut more from there)
At least the seat post but that accounts for some 150gr. Don't know exactly what else.
Edited.
https://www.scott-sports.com/ca/en/prod ... =274720019
They're quoting 1190 for my size but of course it won't be bang on
With the BR link above for the groupset, that one had a 172.5mm crank and a PM. I use a 165mm only and I only tend to use a left arm PM which is ~30g(whenever that'll be available)
We'll see. I do think its a bit optimistic as well, but worth the try. I hate that Shimano doesn't have a 12sp group at the moment and I refuse to use Campy.
Scott Addict Disc 2020
My LBS has received the Creston combo today, and its slightly heavier than expected at 322g
Enviado desde mi MI 9 mediante Tapatalk
Indicate stem length and width
Also, for the holes underneath the bars
- what size bolts does it take?
- how far are they center hole to center hole?
Thinking we can use other aftermarket mounts instead of buying the Scott one
Also,Someone on Instagram quoted 7.5kg for a stock XS RC20
Its a 110x420g32ecs wrote:Indicate stem length and width
No idea about the bolts
It's inline with expected. Keep in mind that they referred 290gr or so but for the smaller versions.kolau wrote: ↑Fri Nov 08, 2019 2:27 pmIts a 110x420g32ecs wrote:Indicate stem length and width
Yeah, I've also found out today that the Scott's GPS mount is rather expensive at around 60e!!g32ecs wrote: ↑Fri Nov 08, 2019 2:19 pmIndicate stem length and width
it was made in conjunction with k-edge, so I would expect the price to be on those values... I think the margin is quite high, regarding the "Syncros Stem RR iC Computer mount", so you may or may not be able to strike a good deal for itpmprego wrote: ↑Fri Nov 08, 2019 5:08 pmYeah, I've also found out today that the Scott's GPS mount is rather expensive at around 60e!!g32ecs wrote: ↑Fri Nov 08, 2019 2:19 pmIndicate stem length and width
If my LBS where I'm buying the "lower end" addict rc does receive some integrated handlebars I'll try to get some measurements!
I went on eBay and searched under "Integrated Handlebar mount" and found this:
https://rover.ebay.com/rover/0/0/0?mpre ... 3026679717
Also found a K Edge one for $40
I couldnt imagine Scott making it any different from these 2. There's also ones that have elongated holes so it's not limiting hole wise.
There you go, problem solved, money saved.
I've been reading companies also making new integrated cockpit with hidden cables in a very similar fashion to what Scott did in the Addict.g32ecs wrote: ↑Mon Nov 11, 2019 5:43 amI went on eBay and searched under "Integrated Handlebar mount" and found this:
One of those is Token and another is FSA (Portuguese company swiftcarbon just presented their new bike with fsa cockpit with fully hidden cables just like the addict) . I'm not sure but maybe one of their new products would already work on the addict. I don't know the exact measures to know if they are compatible. But it clearly is a matter of time for such products to appear.
Wondering how's your project coming along...Nautiboy wrote: ↑Sun Oct 06, 2019 4:41 amcsc.jpg
That will be my next project and scheduled to complete in Dec 2019 - 6.3kg all in including pedals. My last 2015 Addict SL was 5.5kg, and it was way too light to ride sensibly but was my very 1st weight weenie project - so I had my fun and learned a lot from it.
This Scott RC2020 is really interesting.....hope it rides well, will update once is built.
Cheers
Still waiting for the frameset to land....estimated Dec 2019. And I kept changing my mind on the parts...but these are what I've gotten to date:g32ecs wrote: ↑Sat Nov 23, 2019 6:39 amWondering how's your project coming along...Nautiboy wrote: ↑Sun Oct 06, 2019 4:41 amcsc.jpg
This Scott RC2020 is really interesting..... I hope it rides well, will update once it is built.
Cheers
SRAM Red AXS Upgrade kit Groupset - Arrived
Campagnolo WTO45 wheelset - OTW
CaneCreek EE Wing in Oil-stained crank arms to match the "Scott Decals" - OTW
Carbon-Ti Carbon Chainring - Arrived
Supercaz Titanium Oil-Stained bottle cages - Arrived
Time XPRO 15 pedals - Arrived
ESI Bartape - Arrived
Schwalbe PRO One TT 2020 tubeless tires 25C - Arrived
Supacaz Oil-stained bar end caps - Arrived
Basically.....it will be a Black bike with Oil-stained little parts here and there....hope it do not turn out to be cheesy looking.....
This is an RC Pro correct?Nautiboy wrote: ↑Sat Nov 23, 2019 2:30 pmStill waiting for the frameset to land....estimated Dec 2019. And I kept changing my mind on the parts...but these are what I've gotten to date:g32ecs wrote: ↑Sat Nov 23, 2019 6:39 amWondering how's your project coming along...Nautiboy wrote: ↑Sun Oct 06, 2019 4:41 amcsc.jpg
Cheers
Im heading to my LBS today to initiate some my purchase. Im set on the RC Pro frame myself.
