If, by legar, ou mean uci-legal you cannot as you'd be not touching the hoods and in essence replicating the puppy-paws position which was banned (made illegal).wheelie wrote: ↑Wed May 11, 2022 3:19 pmIt's my friend bike and TT bars, they are quite short indeed, you can't put the elbows like on normal tt bars and grab the extensions.billythestickboy wrote: ↑Tue May 10, 2022 1:08 pmHow are you getting on with these TT bars? I've got a 70.3 coming up in 7 weeks and from doing a ride of the course on Sunday it's more of a road bike course than TT bike, so I was thinking I might invest in these.
They do look very short though, can you switch the armpads around to face backwards?
The plan for now is to make a custom attachable extender, from aluminium maybe?
The good point - without modifications, you can, (i guess), use them legally on a group ride/race, because the extensions length is within the shifters.
Scott Addict Disc 2020
It IS possible, but you will loose 5y of your life doing this (I managed to do it when I upgraded to the IC SL combo, but I literally cried...)
Finally got my superheavy stem.
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
We're very similar in build I went with a 58 and am happy with it I do have high mobility and will probably be slamming the stem as well.
Does anyone know wether the original Syncros alloy wheels come with tubeless tape installed?
I just ordered another cassette intending to use my original wheels with wider more comfortable 28 tires tubeless. One thing I am worried about. I noticed when I first installed my Winspace wheels that the gearing didn't shift as cleanly as before on the back. Why is that? Am I running into a problem of having to readjust the rear mech every time I change wheels?
I was dreading the chain dropping issues with Sram, and surprise surprise, I am having that issue too. I've read that it can depend on the frame. Does anyone else have issues with Sram on their Addicts?
No, Capital 2.0 wheels do not come with tubeless tape (at least the few ones I have had in my hands), but are tubeless compatible so just take any tape and install (though the schwalbe one tyres thet ship on those wheels are not tubeless ready...)Roadbiker10 wrote: ↑Sun May 22, 2022 4:22 pmDoes anyone know wether the original Syncros alloy wheels come with tubeless tape installed?
My Sram Force AXS drops chain in the front pretty often when I shift from big to small chainring on a steeper climb (I know I know...). Tried to change a few things in the FD setup but no luck so far.
Interestingly the new 12speed Ultegra Di2 FD tends to do the same as I have heard in our local club...
I had the issue with chain drop when I first got my bike. Brought it to a bike shop, and they helped me adjust the limit screw, and it shifts ok now
Thanks. I will be using Conti S TR on them. Though I'll wait until I get the cassette to see wether there are any alignment issues. If there are I will abandon that idea. I can't adjust the rear mech every time I change wheels.ice29 wrote: ↑Sun May 22, 2022 10:35 pmNo, Capital 2.0 wheels do not come with tubeless tape (at least the few ones I have had in my hands), but are tubeless compatible so just take any tape and install (though the schwalbe one tyres thet ship on those wheels are not tubeless ready...)Roadbiker10 wrote: ↑Sun May 22, 2022 4:22 pmDoes anyone know wether the original Syncros alloy wheels come with tubeless tape installed?
It happened once every ride om my first three rides. My last ride it happened 3 times. This is after I had it done by a shop. Every time it fell on the inside but once when it did on the outside. I noticed it only happened when I was going slow, like in a turn going to the small ring.
I was thinking about maybe switching to Shimano in the future, didn't know they also had issues with that.
I already had it adjusted by a shop and now I'm going back to see wether they can do something. Though I've read about nothing working for some people.Hanpotatoming wrote: ↑Mon May 23, 2022 7:05 amI had the issue with chain drop when I first got my bike. Brought it to a bike shop, and they helped me adjust the limit screw, and it shifts ok now
I need some help. I will be cobtacting Scott directly as well. I stupidly left my front thru axle on the roof of my car. It fell on the road and someone ran over it. Now the axle itself seems fine apart from a bit of the threads have been stripped. But the issue is that round ring which the axle goes through has been damaged and isn't flat anymore. It seems to work holding the wheel in place. But it is grinding in to the carbon on the fork when tightening.
So where do I get this part? Is it best to contact Scott, lbs or somewhere else are they available?
I think every Scott dealer will have one on stock ?!
Or, if I understand the problem correctly, Robert Axle Project. They ship very fast so the relatively small cost could be worth it just to get riding again.
Warning, when I ordered my Axle for thia generation of Addict they had the size wrong on their axle finder. No idea if it's been fixed, I did notify them of the issue obviously.
