Scott Addict Disc 2020
protocol_droid
by protocol_droid
Ive got a brand new ic sl 40/100 if anyone needs one
Sent from my SM-G991U using Tapatalk
naked 3po, the first weight weenie.
pmprego
by pmprego
Selberto wrote:
Mon Jun 14, 2021 10:42 am
Hi Guys,
anybody has a Syncros Creston IC SL Cockpit in 40/110 or 40/120 for sale? Need an upgrade. :-)
The ic sl hoods reach is 5mm longer than the non integrated version. Take that into account.
Selberto
by Selberto
pmprego wrote:
Mon Jun 14, 2021 4:17 pm
Hi Guys,
I know that.thanks a lot for your advice.
powpow
by powpow
Hi, a few seatpost questions. What is the seatpost setback for a 54 Addict? Anyone know if it's the same as the Foil?
I need a 0mm setback but I'm a bit confused by the Syncros info. This 0mm setback post seems to have setback..??
https://www.syncros.com/us/en/product/s ... t-seatpost
Also, does the SL aero post fit the same as the Duncan 1.0 Aero post (assuming they are different)?
Thanks!
protocol_droid
by protocol_droid
powpow wrote:Hi, a few seatpost questions. What is the seatpost setback for a 54 Addict? Anyone know if it's the same as the Foil?
Thanks!
54 is 5mm. The sl aero and duncan aero both fit the addict rc.
TheMalahat
by TheMalahat
Selberto wrote:
Mon Jun 14, 2021 11:12 am
Where did you get it from?
Just lucky enough to know the only local Scott vendors for my Province - they hated the reach on the bar for their new '21 RC whip, so I bought it from them because it fit me like a glove! :D
Karvalo
by Karvalo
jimmyt
by jimmyt
What Syncros Creston IC SL size would I need to replace the Syncros Creston iC 1.5 Compact Alloy 420mm width w. 100mm stem, to have the same handlebar reach and stack? How much weight would I gain replacing the stem and handlebar? Anything to keep in mind (eg do all cables fit (Di2 Ultegra) when buying and installing?
pmprego
by pmprego
jimmyt wrote:
Tue Jun 15, 2021 8:47 pm
The IC SL bar has 5mm more reach at the hoods thus it's not possible to exactly replicate the alloy version. You either get +5 or -5mm.
The alloy version also does not have flare. The integrated has which means that a 40cm bar (at the hoods) is 42cm (41.8mm to be exact) in the drops.
Marvinman
by Marvinman
Could someone kindly point me in the direction of suitable replacement headset bearings please? I'm no mechanic and I want to make sure I get the right option.
Thx
jimmyt
by jimmyt
pmprego wrote:
Wed Jun 16, 2021 6:44 am
Thanks @pmprego! The choice would then be a 40cm bar with a 90mm or 100mm stem. Does anybody know how much weight I would gain replacing the stem and handlebar? Any other things to keep in mind if I'd like to replace it myself?
Addict15
by Addict15
Marvinman wrote:
Sat Jun 19, 2021 3:14 pm
https://www.scott-sports.com/nl/en/prod ... 4660001222
This one obv will work, but it seems to be out of stock almost everywhere.
You could also buy two separate bearings (52 x 40 x 8 with 45/45 degree angles)
protocol_droid
by protocol_droid
I have a brand new 40/100 ic sl if youre interested
pmprego
by pmprego
jimmyt wrote:
Sat Jun 19, 2021 4:25 pm
In terms of weight savings I think it's around 250gr. The non integrated combo is really heavy. And the ic sl is really nice looking imo
Marvinman
by Marvinman
Addict15 wrote:
Sat Jun 19, 2021 7:38 pm
Thx - as with lots of stuff at the moment 'out of stock'. I'll find some other options hopefully
