Campy BB clarification
biwa
by biwa
About to try the first Campy groupset (Chorus) after spending time with Shimano. A quick question on my understanding about their BB system.
Do I simply need a pair of BB cups (e.g. https://www.chainreactioncycles.com/us/ ... -prod25576) to go with the crankset as the bearings (e.g. https://www.chainreactioncycles.com/us/ ... -prod26127) are already on the cranks?
And then what is this (https://www.chainreactioncycles.com/us/ ... -prod85637) for?
uraqt
by uraqt
If it's the Chorus Ultra-Torque crank, and I am 99.99% sure it is, then you just need the cups to match your frames BB. Unless it's a Cervelo then there are issues with campy bbright cups and there are much better solutions for BBRight and Campy cranks.
C
ianeire
by ianeire
If you're buying the groupset new then the cups probably already come as part of the whole package. But your understanding is correct. The whole system when on the bike looks like the Shimano HollowtechII set up, but where the bearing for Shimano comes pressed into the cup, the bearings on Campy UT and PT are pressed on to both cranks and then seated in the cups during installation.
The square taper BB is for square taper cranks which you won't have unless looking at an old groupset.
1415chris
by 1415chris
A bit of clarification.
PT's spindle is one piece attached to DS, in UT two piece spindle attached to both sides.
As a result in UT bearings are pressed on the spindle on both DS and NDS sides. In PT only DS side comes with the pressed on bearing. DS side bearing is pressed in the bb cup.
AJS914
by AJS914
biwa wrote:
Sat Jun 08, 2019 6:07 am
Correct. You just need cups. The bearings in your 2nd link are replacement bearings.
The bottom bracket in your last link is for older pre-Ultra Torque 9/10 speed cranksets.
biwa
by biwa
Thanks everyone for the confirmation
bm0p700f
by bm0p700f
There are different versions of ultra torque cups for different bb standards.
Miller
by Miller
OMG I feel old. I spent decades cycling on bikes with square taper bottom brackets. Now some young person doesn't even recognise what it is.
Calnago
by Calnago
Ha, pretty funny... and let’s not forget the time before “cartridge bottom brackets” when there was just loose bearings against the axle cone and the inside of the cup. When Italian threaded BB’s would unscrew themselves if they weren’t tight enough. Yes, I guess I’ve been around awhile... ha.
Look565w
by Look565w
Calnago wrote:
Mon Jun 10, 2019 6:32 am
Funny you should mentioned that, Calnago, that's exactly what happened when I rode my Arabesque last Friday :shock:
Started the ride with a noisey chain (chain rubbing the cage) ......... then 25km later & going up a slight hill, the crank seized up. Stopped & look down to see this:
Made it home with the bike in the back of the taxis & took these photos:
The cup on the non-drive side have also somehow "screwed it self" into the BB shell :shock: forcing the inside face of my ND side crank to jammed against the edge of the BB, causing score marks ........... ouch! :(
Now bought a lock-ring tool with a 1/2 inch attachment slot so I can attach it to my torque wrench to give it the 70nm torque (which I didn't do in my initail installation ........ school boy error) that's recommended ....... lesson learnt! :oops:
Now, hopefully the damn thing will stay in place!
Karvalo
by Karvalo
Wow. I understand (kinda) the flaw in ITA vs BSA thread direction but always thought it was more of a theoretical effect, not strong enough to cause real world problems!
Calnago
by Calnago
I rode a 1991 Basso Loto across the southern US in 1996. Somewhere in Texas the BB started unscrewing on the drive side. Had to just keep screwing it back in as best I could with whatever I could find until we got to San Antonio where I could finally get access to a proper tool to tighten it down. It’s the process of “precession”. It is very real. What happens is the loose bearings are rotating between two surfaces, the axle itself and the inside of the screwed in cups. If you think about the direction of rotation of the actual surfaces on each other, you’ll see that between the bearing and the inside surface of the cup the rotational force of the bearing is “lefty loosy”. So... in the absence of a left hand thread (like there is in English BB shells), if the cup isn’t tight enough it will eventually walk itself out.
In your case I’d clean up the threads and use a threadlocker and maybe 50Nm of torque. I think I’d use Loctite 222 (low strength) first, keep an eye on it, and if it doesn’t walk back out you’re golden. If it does, then go up to Loctite 242 threadlocker (med strength). And don’t confuse threadlockers with retaining compounds. Back in those days I don’t know that anyone would have even heard of using any of these things on a bicycle (grease was universally used on pretty much everything). Now we have threadlockers, retaining compounds, anti seize pastes, carbon paste, etc., etc.
