Bottle touch frame before nose of bottle cage Carbonworks in vertical in Supersix
mendiz
by mendiz
Hello, I have mounted the bottle cages Carbonworks and the bottle touch the frame of Supersix Evo Hi mod lightly before the nose of the bottle. Any ideas to correct this?
You don´t stop riding when you get old, you get old when you stop riding.
Dan Gerous
by Dan Gerous
Change cage for one with holes that brings the cage higher up or use bottles that taper a bit more at the bottom.
mendiz
by mendiz
Thanks, I want to use these cages, are awesome, I will look for another bottles, this is Elite corsa bottle
hannawald
by hannawald
I had same issue with Canyon Ultimate. Wrote an email to Carbonworks, they replied that a bottle cage with shorter nose was in development. It is already half a year..
mendiz
by mendiz
I think I will go to a man that works with carbon, he repaired a hole of my old Ax Lightness Endurance. Put a bit of carbon above the nose to shorten the nose
C36
by C36
Would either glue a small piece of rubber to place the bottle slightly up or put few layers of shrinkable tubes to achieve the same result.
You never know what new bottle you may have to put there on my SS I put a small frame protection there just in case
mendiz
by mendiz
Thanks a lot, C36, is that kind of tube of my pic I guess, which glue do you use to fix the shrinkable tubes?
C36
by C36
Yes! You have different thickness and different ratios (initial diameter/ retracted diameter). Here “any” could work
573
by 573
What year Supersix and what size?
I have no issues with the carbonworks cages and loads of different bottles on 2 different supersix and CAAD12 frame (size 54).
mendiz
by mendiz
Is 2019 SS Evo HM size 52
CarbonWorks
by CarbonWorks
Hi guys,
I am working on a cage with a shorter distance to the nose of the cage.
So this will solve the problem with small frames soon.
Simon
carbonworks.de
