Di2 Shifters
Hi all,
I'm helping a friend to plan his bike build. he is asking if there is any significant change to R9150 shifters from 9070. Online article seems to suggest they are quite similar, just abit slimmer and with textured rubber hood. Any one have experience with both? what about the braking side, are they very different? like softer pull or better modulation/feel? thanks.
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
https://www.youtube.com/watch?v=1EnUqB0ww3UWorkonSunday wrote: ↑Tue May 21, 2019 6:40 amHi all,
I wouldn't hesitate to go with the 9150 levers over the 9070. The shifter hood is beefier on the 9150 and there is more there to hold on to. And the tactile feedback on the 9150 is a lot better. You can better tell when you've completed the shift since you get a nice click - the buttons on the 9070 levers are too mushy.
The 8050 shifters are virtually identical to the 9150 if your friend is looking to save a little. I cannot tell any difference between them.
thanks for your feedbacks guys. i will forward the message.
- Dan Gerous
No but, having a bike with Di2 and the other with eTAP, I changed the Di2 button configuration so the logic is more alike. Now my right hand upshifts, left hand downshifts, the rearward buttons control the rear derailleur, front ones the front derailleur. So now the much more used rear shift buttons are like eTAP. I get less mixed up when I go from one bike to the next.
As a bonus with the older mushy Di2 buttons, it's a lot better when it's cold and I wear full fingered gloves that make it harder to feel which button you are touching. The way mine are set, it's easier to find the rear derailleur buttons and be sure that's what you'll press as they're on the rear edge.
Impossible to do simultaneous command.
However, my Di2 set up as:
left big button: bigger cassette (same as sprint shifter)
right big button: smaller cassette (same as sprint shifter)
left small button: smaller chainring
right small button: bigger chainring
The cassette shifting logic is like Etap, but front ring is different.
That's different from my set-up. The front button is taller (easier to press from hood, i use sprint shifter when in drop), and more pronounced (have texture, and sit more outward than back button) so i find it easier to find therefore i set the front button for rear derailleur.Dan Gerous wrote: ↑Thu Jul 25, 2019 8:21 pmAs a bonus with the older mushy Di2 buttons, it's a lot better when it's cold and I wear full fingered gloves that make it harder to feel which button you are touching. The way mine are set, it's easier to find the rear derailleur buttons and be sure that's what you'll press as they're on the rear edge.
We can't switch bike and shift correctly for sure.
I'll just add that the more pronounced click is also true on the newest Ultegra shifters compared to the previous version. I like it better but I wouldn't upgrade just for that. I prefer the fatter hoods on the newer version but again it's not that big a deal for me.BdaGhisallo wrote: ↑Tue May 21, 2019 11:14 amI wouldn't hesitate to go with the 9150 levers over the 9070. The shifter hood is beefier on the 9150 and there is more there to hold on to. And the tactile feedback on the 9150 is a lot better. You can better tell when you've completed the shift since you get a nice click - the buttons on the 9070 levers are too mushy.
