DIY RD alignment tool?
Catagory6
by Catagory6
are the threads a standard size, that i could get a bolt from a hardware store?
PeytonM
by PeytonM
The threads are metric fine M10 x1.0, not common but readily available on eBay...
AJS914
by AJS914
An old rear wheel with a threaded axel makes the perfec DIY tool. Undo the derailleur and let it hang to the side. Screw the end of the axel into the hanger. Measure all the way around with a tape measure. The distance betwen both wheels should be equal all the way around.
jfranci3
by jfranci3
Are you trying to bend your RD or hanger into position or just get the jockey wheels and cogs lined up? If the later, putting the RD in a middle cog, lining up your eye with that cog from the rear, and lining up the top jockey wheel (shift back forth, repeat) is a lot easier than using a tool. Tune has a laser one, but that's silly - you're really checking the squareness of the laser rig more than you are the RD.
tommasini
by tommasini
Here is a link to my earlier thread about accidently coming across a tool that was being sold as an alignment "muscle" tool only but by having the seller lengthen the handle it servces also to get measurements off the rim. Works excellent
viewtopic.php?f=3&t=148242&p=1356453&hi ... l#p1356453
kdawg
by kdawg
AJS914 wrote: ↑
Fri May 17, 2019 2:30 pm
That’s exactly what I do - accurate and easy to adjust because of the diameter of the wheel.
I'm left handed, if that matters.
alcatraz
by alcatraz
Another rear wheel user here +1
I also use the same rear wheel on the trainer.
