Cannondale EVO Hi MOD upgrade worth it or not
ukracer
by ukracer
Hi All,
Currently have a nicely set up 2015 Evo thats light enough at approx 6.5kg.
Other than weight saving is worth upgrading to the Hi Mod version same years or later?
What will i notice if anything ?
alcatraz
by alcatraz
I was looking covetously at supersix himods for a year or two. Seems the himods are around 150gr lighter than the non himods. (could be wrong) The 2016- fork is new and lighter than the old one.
How much is ~200gr worth to you?
Now I've changed my aim to getting a Focus Izalco Max. Check it out. It's got a better reputation for reliability and it's equally light or lighter even. Standard 27.2mm seatpost, pf30 = cheap light cranks, alloy headset bearings, good stiffness numbers.
A user stripped the paint and got to 660gr. Fork ~280gr. And the weight doesn't differ as much from frameset to frameset. No need to worry as much about getting one from a heavy batch. :thumbup:
