Best expander plug with or without weight being a factor?
Lewn777
by Lewn777
I was thinking about getting a new exapander plug I've got four, but none of which I love. Been having some issues with some slipping and some of the weights seem heavy.
Ideally:
-sub 40g
-doesn't slip, even when over-torqued from cap bolt
-supports bottom stem bolt
I'm aware of
-Cannondale Expander Top Cap
-Extralite UltraStar 3 Expander
-Schmolke Expander SL
-PRO expander ud carbon (looks heavy but non-slip)
Anyone got any favorites or recommendations?
FIJIGabe
by FIJIGabe
In the past, I've used three different expanders: stock Bontrager (28g), UltraStar 2 & UltraStar 3. I found the US2 to be pretty good (no slipping), but the 3 slipped. I'm currently using the stock Bontrager unit, because it just doesn't move.
Lewn777
by Lewn777
FIJIGabe wrote:
Tue May 14, 2019 3:03 pm
Stock Bontrager seems like a reasoanble weight, and no slipping issues, might take a look at that.
Nice suggestion. :thumbup:
nickf
by nickf
I have been using the ultrastar 2 for a few years now on multiple bikes with no issues. I have one on my Trek Checkpoint, Cannondale SS EVO HM, and a Enve 1.0 fork. No slipping, easy setup, weighs close to nothing.
maverick_1
by maverick_1
Kuwahara-hirame expander plug below.
Bullet proof, just like the Campy/Shimano’s QR.
Made in Japan.
33 grams
https://www.kuwahara-bike.com/hirame-mu ... ure-anchor
shuttlenote
by shuttlenote
FIJI: Is this the Bontrager you're using?
https://www.tritoncycles.co.uk/componen ... cap-p20914
asiantrick
by asiantrick
My Addict SL been suffering from expander plug slippage. I recently switched to Deda Expander Bung and been super happy with it. Absolutely no slippage and very well made. You can get it from wiggle for $16
https://www.wiggle.com/deda-expander-bung/
PinaRene
by PinaRene
Carbon - ti with Riesel topcap on 2 out of 3 bikes - they don't slip with topcap on 3Nm and it's enough for bearing preload. Did cobble rides - bad roads and they still are perfect. Ordered @ R2 bikeshop in Germany.
1415chris
by 1415chris
Extralite mk2, light, mount and forget, many years on couple of bikes.
PinaRene, that's a lovely, cool top cap, thanks for a tip will definitely get one.
dastott
by dastott
Had slippage with the light Cannondale one recently. Have put the heavy (50g) Cannondale one back on so this thread is well timed for me. Thanks.
Lewn777
by Lewn777
maverick_1 wrote:
Tue May 14, 2019 5:22 pm
Made in Japan.
33 grams
Seems like a good option, but for the life of me I can't figure out how to buy this from this website. :noidea:
EDIT: Alex's cycle https://alexscycle.com/products/hirame- ... e-anchor-1
Lewn777
by Lewn777
Anyone had any luck with some of the OEM plugs? We know that Cannondale heavier one and Bontrager are proabably quite good. It's just I'm in Asia and would like to get something out of a shop if possible. The 10 day postage time from Europe is quite annoying.
Anyone got anything on Specialized, Giant (is it even the same size?), Merida etc
Lewn777
by Lewn777
PinaRene wrote:
Tue May 14, 2019 9:13 pm
Cobble rides are a great test, and 3nm is a good torque, this seems like a good option. Thanks. :thumbup:
What torque are you using on the plug? 6nm?
Lewn777
by Lewn777
For anyone reading this thread that's new to expander plugs you generally install the expander plug (ideally so that your bottom stem bolt is supported) to a torque of 6-8nm.
You then tighten the top cap bolt to a torque of 2nm-3nm and your stem bolts to the indicated torque (usually 5nm).
Warning overtightening can damage your bike, so unless you have a torque wrench don't mess with the expander if everything is working well although this is an area that can see 20g-40g of weight savings.
Orbital
by Orbital
dastott wrote:Had slippage with the light Cannondale one recently. Have put the heavy (50g) Cannondale one back on so this thread is well timed for me. Thanks.
I initially had slippage when I went to the lighter one. Use a bit of carbon paste and haven’t had issues since.
