Garmin mount
coresare
by coresare
I can second the Raceware. Light. Just not integrated
coresare
by coresare
I can second the Raceware. Light. Just not integrated. It's what I use.
RocketRacing
by RocketRacing
True, not integrated, but it does hide the garmin in the shadow of the bars.
wheelsONfire
by wheelsONfire
petosagan wrote:
Sat May 11, 2019 10:29 pm
wheelsONfire wrote:
petosagan wrote:
Sat May 11, 2019 8:49 pm
wheelsONfire wrote:If you want a cheaper mount, you can look at this link
http://edge-mount.bike
Dont have enve stem but Thanks
Envoyé de mon SM-A530W en utilisant Tapatalk
Enve stem? Why in heavens name would you need an Enve stem?
There's probably atleast 50 different versions.
Have you even looked at the link?
http://edge-mount.bike/?post_type=product
These mounts cost around 50 Euros and as far as i've seen the F3 cost more (atleast mine did)
I said enve cause someone told me something earlier about enve mount and I just make a mistake, not a big deal..
On the f3 mount, I see 59$ on the website and they give 15% off.. so 50€ should be higher.. but I have to see if edge have something for my stem... cannondale c1
Measure center to center of the bolt holes of your stem, then you pick the size suiting your stem.
Regarding F3 mounts. If you are in EU those mounts (if imported) will be taxed.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
petosagan
by petosagan
My cannondale seems to be 14mm
And on edge mount I see 9mm or 17 mm nothing between unfortunately
Dan Gerous
by Dan Gerous
Odd, my Cannondale C1 stem has a 24mm spacing (horizontal distance between two bolts at their center) which would require this model.
petosagan
by petosagan
Dan Gerous wrote:Odd, my Cannondale C1 stem has a 24mm spacing (horizontal distance between two bolts at their center) which would require this model.
Lol.
Yep 24.. not 14 ... Sorry
reknop
by reknop
Probably cheaper but not necessarily less quality. At least I'm super happy with the Edge Mount for my Pro Vibe stem.
Sent from my Nokia 8 Sirocco using Tapatalk
https://www.remo-knops.com/cycling/
wheelsONfire
by wheelsONfire
reknop wrote:
Sun May 12, 2019 4:44 pm
No, not better. But i have 14 stems and i for sure will buy a new as soon as a light weight - 10 degree stem comes out.
My Easton is 138g at 120mm.
Buying a fixed size front out mount wouldn't be reasonable for me. Last 6-7 months alone, i bought 3 new stems.
I'd been going for Alpitude mount (15g but no bolt), but i don't believe in a stem front out mount, held with only 1 bolt.
Probability that it start to dip left or right seems very likely. I might be wrong though!
F3 mount isn't really that light (28g + 1g for alu spacers but no bolts), but it's stiff and it's modular. I doubt it'll dip so it's making reason from my point of view.
Bikes:
Ex bike; Vial EVO D
reknop
by reknop
I don't switch stems that often Image
petosagan
by petosagan
That kind of mount seems to be nice.
https://rover.ebay.com/rover/0/0/0?mpre ... 2675579365
