THM Clavicula SE crank
eforce123
by eforce123
Does anyone have any experience running this lightweight crank? My LBS said they fall apart and do not recommend them at all. However, this same shop doesn't like campy either so....
NiFTY
by NiFTY
Why are you talking to a shop that doesn't sell THM about THM products? Plenty have them. They go well.
coresare
by coresare
I have them. I'm 150 lbs so not a very powerful rider. No issues with them so far. Nothing beats Shimano chainrings though.
alcatraz
by alcatraz
NiFTY wrote:
Mon May 06, 2019 4:14 am
I think in a way the same argument goes the opposite way. :lol:
"Why are you talking to someone with an economic interest about the products they sell?"
No matter how smart your lbs is in your eyes it's probably wise to look through real buyer reviews (not one but several) on the internet beforehand.
tabl10s
by tabl10s
eforce123 wrote:
Mon May 06, 2019 3:51 am
I have three SE's and a Classic. No problems.
2015 Pinarello F8: 13.13lbs/5.915kg(w/Roval 64's).
2016 Rca: 11.07lbs/5.048kg.
2018 Rca.
2018 S-Works SL6 Ultralight: 12.03lbs.
mike
Resident Pro
by mike
it is a lie. the only problem with claviculas is the non drive bolt which can come loose or shear. the new non drive bolt corrects this.
KCookie
by KCookie
Other than stated above which did actually happen to me, out on a ride the crank arm decided to come off and hang from my shoe, they are an excellent crank. The cranks now come with two tiny grub screws which holds the bolt in place. Never had a problem since.
wheelsONfire
by wheelsONfire
The only thing i could argue about is the Q-factor of all THM cranks.
Very wide, too wide even!
It would also be nice to see a version with increased chainline
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
AndreLM
by AndreLM
The q-factor of a Clavicula SE is 148mm. Shimano DA is 146mm, and Campy SR is 145.5mm. That is 1-1.2mm difference per side.
Enviado de meu SM-G950F usando o Tapatalk
kode54
by kode54
I have the SE on a few bikes and a M3 on another. no issues of falling apart.
If properly installed, you shouldn't have an issue with them...like NDS crank falling off. I always use Loctite 242 on the clamping bolt and after tightening up the pre-load bolt, I tighten it up a bit more after torquing the clamping bolt.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
trimenc
by trimenc
Just like Kcookie, I too had the SE cranks the minute they were first released (without the new and improved grub screw) and I did have the crank arm come off during a ride one time. I contacted THM, they fixed the problem and their customer service was top notch. I have never had another problem, despite not using the grub screw but instead just adding some Loctite on the threads.
I am certain that wheelsONfire nor anyone else can tell a 1mm width difference in a set of cranks.
RocketRacing
by RocketRacing
Any places to get them at a better price? Or annual sales? Just so expensive!
eforce123
by eforce123
thank you everyone for the replies.
PrinceEdward
by PrinceEdward
Also experienced the cover cap fallen while riding. Afterwards apply carbon paste and tightened a bit, no problems since that...ImageImage
我從使用 Tapatalk 的 Pixel 發送
dgasmd
by dgasmd
RocketRacing wrote:Any places to get them at a better price? Or annual sales? Just so expensive!
Not the only one wanting to know really. I’ve lusted after a set of these for years!
