Shimano Special grease Dura Ace
1415chris
by 1415chris
I am trying to buy a new grease, my old "Special grease Dura Ace" is about to run out. Is Shimano's Premium grease today's equivalent of old Dura Ace one? When typing Dura Ace grease, interner returns Shimano Premium grease. Although I'd prefer to stay with trusty, good quality DA, I don't mind trying something new, if only the quality is at least at the same lave with DA.
pdlpsher1
by pdlpsher1
Yes it's the same grease. I've been using the Dura Ace grease for wheel bearings but recently I've switched to Finish Line extreme flouro. The Dura Ace grease is super tacky and very good for wet weather protection. But I do almost all of my rides in the dry. If you have concerns about friction you might be interested in these test results.
talltales
by talltales
If price is at all a concern, you may want to try Motorex fett 2000. Its very similar, possibly the same as Shimano Premium grease. Also sold in a smaller tin as Motorex bike grease 2000.
1415chris
by 1415chris
Thanks for confirmation, I would defenitely consider recommended options.
snaxez
by snaxez
I was thinking to buy this: http://www.wychbearings.co.uk/LGHP2x420ml_grease.html Big tub to last for a long time and looks similar to CeramicSpeed Allround Grease
MrMagura
by MrMagura
Unless you're riding in very dry conditions, and are willing to replace the grease very often, the above test shows an insignificant part of the picture.
What mostly causes drag in a bearing, is damage, corrosion, and contamination.
Counting out the wrong amount of grease.
A high load grease that keeps corrosionat bay, and avoids damage to the bearing, is by far superior in the long haul.
If coupled with good seals, of reasonably frequent service, probably as good as it gets.
Look for industrial stuff. Among others, SKF has a grease suitable for the purpose.
LouisN
by LouisN
talltales wrote:
Sun May 05, 2019 6:32 pm
+1 here.
I've been using Motorex 2000 for more than a decade. I tried Muck-Off Bio Grease lately, but I prefer old MOtorex 2000.
Louis :)
