Chain riding on sprocket teeth (Campagnolo 12 speed)
XCProMD
by XCProMD
Top pulley definitely too close to 32.
Skickat från min iPhone med Tapatalk
mag
by mag
I can only compare with the 11-29 cassette but it really looks to be too close to the 32t sprocket.
How does it look like on the 11t from the side?
Guerdi
by Guerdi
Nice hre wheels I see in the background :thumbup: .
Nejmann
by Nejmann
I’m on 12 speed sr mechanical, and it works flawless. Can I take a picture of anything? I’m on 50/34 11-32
taylorpetie
by taylorpetie
I’ve also played around with the distance between the top pulley and COG (with quarter turn tightening of the screw). For each quarter turn increase, I then restart from scratch (detach tension cable etc... reset starting point).. Increased the pulley distance from around 5mm to point there was around 6.5mm distance and same outcome regardless of the distance.
taylorpetie
by taylorpetie
Nejmann wrote:
Sun May 05, 2019 3:26 pm
Any chance you take a pic of the top pulley alignment with the smalll CoG from the rear? I’m curious whether there is a slight inward angle. And curious how much space you’ve set between the COG and top pulley. Thanks :)
Nejmann
by Nejmann
taylorpetie wrote:
Sun May 05, 2019 5:33 pm
What ring in the front? :thumbup:
taylorpetie
by taylorpetie
Big chain ring. Thanks!
taylorpetie
by taylorpetie
delete double post
Nejmann
by Nejmann
Sorry for the dirty drivetrain, got caught in the rain earlier today. Took some photos on big-small and big-big. :thumbup:
