Pinarello announcement may 1
tabl10s
by tabl10s
Deleted.
2016 Orbea Orca OMR:
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8:
13.04lbs/5.915kg
2018 S-Works SL6(shooting for 11lbs).
milroy
by milroy
You do realise that the red/black colours are the team colours for INEOS.
You can buy the frame in a number of other colour ways.
A red/black one is misleadingly called “Uranus”. I’m not sure what they call the pink/brown one.
kkibbler
by kkibbler
Shrike wrote:
Thu May 02, 2019 9:19 pm
This photo makes no sense. So that’s the floor, because door. So that’s a chair. Is that...a giant plate of giant cherries? On the floor? wtf
tabl10s
by tabl10s
kkibbler wrote:
Fri May 03, 2019 6:14 am
Bwahahaha!
15.0lbs/6.804kg.
2013 Wilier Zero.7:
13.02lbs/5.906kg.
2016 Rca:
11.07lbs/5.048kg.
2015 Pinarello F8:
13.04lbs/5.915kg
Shrike
by Shrike
Stereotypical 80s decor, who knew the reference would be too subtle for some after a rant about black and white 80s colourways.
And yes F12 has another colour aside from Team Ineos black and red. Black and red again. Oh and some other colour just in case someone doesn’t like black and red.
wingguy
by wingguy
ome rodriguez wrote:
Thu May 02, 2019 12:40 am
Bad news - fork steerer now is straight 1 1/2”, this means no aftermarket stems just the most talon.
Just seen one in the flesh, the fork steerer isn’t straight 1-1/2, the stem clamp is still 1-1/8. The upper bearing is 1-1/2 to facilitate the internal cable routing by the look of it. Talon probably still only compatible bar to get the cable routing to work though.
fogman
by fogman
Are there cable ports in case you want to route the cables the traditional way? I didn’t see any in the photographs.
It's all downhill from here, except for the uphills.
survivor
by survivor
The stack and reach dimension changed slightly for F12. For size 47 and 50 it looks like F12 is having higher stack and shorter reach compare to F10 and F8.
TobinHatesYou
by TobinHatesYou
survivor wrote:
Fri May 03, 2019 4:03 pm
The Pinarello audience is a few years older now.
RedbullFiXX
by RedbullFiXX
TobinHatesYou wrote:
Fri May 03, 2019 5:41 pm
True, Froome is no spring chicken...
3Pio
by 3Pio
But for size 53 seem that have lower stack...
Ritxis
by Ritxis
wheelsONfire
by wheelsONfire
Who's going to be the first on one?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
hannawald
by hannawald
Froome?
3Pio
by 3Pio
wheelsONfire wrote:
Sun May 05, 2019 11:16 am
Obviosly someone who have more money then taste.... Im Considering the Dogma F12 as IQ test.. If u buy one, u failed the test....
