Stem height?
TonyM
by TonyM
Looking at the stems on my different bikes I just noticed that they have different heights.....(Pro Vibe, Deda Superleggero, Deda Zero100,...)
Is there however a “standard” height for stems?
wheelbuilder
by wheelbuilder
Not sure if there is a "standard" height, but I love the look of low stack height stems. Particularly the Basso stems.
CLEAR
by CLEAR
By standard, i believe its referring to 4cm normally for A head stem. But most stems i have used are ib 35mm-38mm actual stack, from ritchey, deda, 3T, mcfk, ax, etc. Basso stem stack is 25mm i believe..
mattr
by mattr
TonyM wrote:
Sat Apr 27, 2019 2:10 am
a standard in the bike industry? What madness is this!!!!
No. As above, anything from mid 20s to mid 40s. Probably enough to actually be an issue for fit. Two nominally identical stems could have the bars 10mm difference in height.
wheelsONfire
by wheelsONfire
I think the unspoken standard is 40mm.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
mattr
by mattr
More likely 38. As in 1 1/2".
But still you're just as likely to find one that isn't.
ancker
by ancker
When I'm cutting a steerer, I always leave room for a 5mm spacer abover the stem.
It doesn't look super clean, but it's a good fail-safe if I (or the next owner) need/want to run a different stem that's slightly taller than what it was cut for.
Dan Gerous
by Dan Gerous
Nothing standard which is fine but it would be nice if component companies always had this measure in their specs, some do but many don't.
biwa
by biwa
40/41mm seem most common
mattr
by mattr
Odd, just been downstairs to check (kids are in bed finally!) and of the 11 stems i have within easy reach, 7 different manufacturers (i'd guess 3 or 4 are rebranded kalloys, but different models), and no two of the same model, 9 of them are between 38 and 39 one is 44 and one is 34. (44 is a fairly hefty and cheap stem on a trail bike, 34 is a fairly crap one that i've never trusted, so it's in a box full of bars) so my "guess" of 1 1/2" doesn't seem to be far off, at least for the random selection of stems i have.
hannawald
by hannawald
Deda Superzero 36mm, Deda zero 100 40mm, Mcfk 44mm (extreme), Ritchey Wcs C260 42mm, Kalloy Uno 7 40mm...
38-40mm is most common. lower or taller is not typical.
Bigger Gear
by Bigger Gear
Just a few more.
Thomson X2: 36mm
ENVE: 41mm
Thomson X4: 40mm
Moots Ti: 43.2mm despite being listed as 45mm (I've measured 2, both non-RSL)
Bontrager RXL: 41mm
Zipp Service Course SL: 41mm
silvalis
by silvalis
Ritchey Logic c260 and superlogic c260 = 42mm
Zipp speed SL = 43mm
Chasse patate
Dan Gerous
by Dan Gerous
FSA SL-K and OS-99: 39mm
Cannondale C1 Ultralight and C2: 37mm
