Anyone tried F3 Cycling Garmin mount?
wheelsONfire
by wheelsONfire
https://www.f3cycling.com/formmount
These seems rather modular which is great if you change stems and computer.
Anyone owning one of these?
(Changing to ti-bolts would be a must)
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Jugi
by Jugi
Yes.
As long as I'm using a stem which is level to ground (or close), the Form mount is perfect for my needs.
moyboy
by moyboy
This looks clean and slick... great idea to fit different bolt patter widths.
shuttlenote
by shuttlenote
Jugi wrote:
Fri Apr 26, 2019 6:15 pm
Yes.
This is pretty important. The K Alloy Stem is just a tad not level, but not enough where it bothers me. So it points down ever so slightly.
Also recommend getting the bridge install tool otherwise the arms move all over the place when you start tightening up the bolts. This also affects how your wahoo/garmin will sit once mounted.
fizzaz
by fizzaz
shuttlenote wrote:
Fri Apr 26, 2019 7:39 pm
Yes.
I second bridge tool. They shouldn't sell the system without it honestly.
TonyM
by TonyM
I have this mount (bought it during their indiegogo campaign) but it is quite complicated to get it in the right position.
Reading that there is a tool meanwhile makes me think that this tool is helpful.....
shuttlenote
by shuttlenote
As fizzaz mentioned, it should be included there's really no good way to align the arms otherwise.
jfranci3
by jfranci3
It's great once setup, but it'll never be level. The rods twist as you tighten the bolts. One strategy that works OK is to tighten all faceplate bolts, not paying attention to the exact position of the rods, then back off the top (non mount) bolts, and then back off the mount bolts a know number of turns. Now focus on getting the rods right while to retighten then known number of turns. Once you've achieved this miricle, retighten the top bolts. This will allow you to tight the mount bolts with less force on the bolt head, saving you some headache.
Noctiluxx
by Noctiluxx
shuttlenote wrote:
Fri Apr 26, 2019 9:33 pm
The arms need to be greased, though still a a massive pain in the ass to align properly.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
wheelsONfire
by wheelsONfire
Hm, i ordered this mount. But i didn't know it was 29 grams excluding bolts.
There should be a way to "fix" the arms without the tool you speak of.
Didn't realize it's almost as heavy as the Edge 130 unit :-(
I was looking at Alptitude Stelvio mount. But it uses only one bolt attachment. I was wondering how this would be enough to hold the Garmin level (not dipping left or right).
Anyone using Alptitude?
Bikes:
Ex bike; Vial EVO D
jfranci3
by jfranci3
You can clamp the arms, but the problem is that you need to get a tool in behind where you’re clamping. It is very tight and you’d end up with a very specialized jig.
Order the light mount while you’re ordering.
Jugi
by Jugi
I didn't find it too hard to get it perfectly positioned by:
1. While installing, put some grease on the arms at points where they contact either bolt spacers or stem's faceplate and the attaching bolt's head.
2. Tighten all stem bolts to specified torque. Resist the arms twisting by hand, but no need to get them perfectly positioned just yet. Just make sure all bolts are evenly tightened.
3. Loosen the other two stem bolts just enough the arms can be turned.
4. Fine tune the arm's position by hand.
5. Tighten the other two bolts back to specified torque.
(6. When in doubt, check the Form mount bolts' tightness. I bet they are reasonably close to spec.)
7. Fine tune the cradle's fore/aft position.
8. Enjoy a perfectly positioned head unit.
sychen
by sychen
Jugi wrote:I didn't find it too hard to get it perfectly positioned by:
Pretty much this..
Wasnt too hard..
Few bolt mounts that also supports a gopro/light mount under.
wheelsONfire
by wheelsONfire
So it seems i would need "short arms" as an extra order. Kind of like the Carbonworks version, but it requires stems with a thread through stem.
Werkings version is also interesting, but going from Edge 130 to 530/830 would require a new.
Also, anyone have any input if these 1 bolt mounts really stay in place?
I wonder if they dip left/ right all of a sudden?
Bikes:
Ex bike; Vial EVO D
