105 di2
quadzilla
by quadzilla
Was talking one of my friends who is a mechanic today. He said the Shimano rep told him to "watch out for 105 di2". Anyone have any other info/rumors?
Brynhildr
by Brynhildr
Okay, This Is Epic
TobinHatesYou
by TobinHatesYou
I'll believe it when I see it. Di2 is basically the only differentiator between Ultegra and 105 anymore.
rainerhq
by rainerhq
Please, Shimano.
Domane
Speed Concept
"Nothing compares to the simple pleasure of a bike ride"
robeambro
by robeambro
That would probably lead to a sudden switch to electronic groupsets. Mech would not disappear but would be pretty much sidelined, in the same fashion as what disc brakes did to rim brakes.
If indeed 105 Di2 is launched, there would be little reason to buy Ultegra mech (you could pay roughly the same and have 105 Di2), similarly to what happens with many users opting for Ultegra Di2 rather than mechanical DA. And the "mid-range" mechanical offering suddenly becomes ever so thin.
TobinHatesYou
by TobinHatesYou
105 Di2 wouldn’t just cannibalize Ultegra mechanical sales, it would cannibalize UDi2 sales. I already see very little reason to buy Ultegra mechanical over 105 mechanical...
gravity
by gravity
What is the reasonable price for 105 di2? I guess if it’s priced at usd1,000 it would be really attractive
Karvalo
by Karvalo
There's not really a huge scope for price reduction in 105 vs Ultegra DI2. All the e-tube parts (wires/junctions/batteries) would be directly shared, all the electronic parts inside the mechs and shifters would be the same, the only difference would be materials and finish on the housings. Realistically, whatever the current difference between 105 mech and Ultegra mech is (dollar amount, not percentage), that's what it would be.
Anyone who thinks hey, 105 is half the price of Ultegra, so 105 DI2 will be half the price of Ultegra DI2.... there's just no way.
Cemicar
by Cemicar
I think it's possible to release a 105 Di2 while securing existing Di2 groupsets. Ultegra Di2 used to have no sprinter switch port or no hidden button... who knows the same thing won't happen again to a possible 105 Di2. Those features can be already enough for buying Ultegra Di2 but synchronized shift also can be disabled if any more differentiation is needed.
Devaluing low-grade electronic groupset too much isn't a good idea. Campagnolo went so far as to deny compatibility between Athena and SR/Record EPS, but I'm not sure it was welcomed by the market given it was quickly gone, once renamed as Chorus EPS.
Miller
by Miller
Cemicar wrote: ↑
Sat Apr 27, 2019 11:47 am
Only by using a different connector. I think Athena/Chorus EPS was pretty much the same as SR/Record EPS under the bonnet, so to speak. The mechs certainly look the same other than surface finish. I have a couple of bikes on Athena EPS. I recently put the Record level Hydro EPS shifters on one of those bikes by soldering Record connectors to an Athena/Chorus interface unit, still with Athena battery and still with Athena derailleurs. Even with the new Ergos, all EPS function is maintained. Shifting is normal, battery check etc normal, derailleur adjustments are normal, no warning light on interface unit.
With motors and electronics basically the same it's hard to see how to make a lower-level e-group significantly cheaper than the higher level groups. Campag couldn't manage it. Maybe Shimano will simply through the sheer volume they would be likely to ship.
mattr
by mattr
Miller wrote: ↑
Sat Apr 27, 2019 12:48 pm
Once the development and tooling is paid for most of the cost is simply what the market will bear. Even in small volumes the electronic components for Di2 will cost next to nothing. I'd not be at all surprised if the *actual* cost of making a rear mech only doubles when you add electronic shifting. Shifters are probably easier and simpler to make than mechs. Front mech will be more added cost, as they are so simple to make in the first place.
In reality they could change the finish on an ultegra groupset, few suble machining changes, bung it out at a 25% discount over Ultegra and *still* make a profit.
Christ, it's whats 75% of the consumer good manufacturers have been doing for decades.
ooo
by ooo
viewtopic.php?t=144106 - this was 2 years ago and now it is cancelled (details removed after they disappeared from shimano.com)
There will be some new di2 parts ultegra level, and non-di2 parts tiagra level, some non-group parts, but no 105 updates
One of the nice things this year there will be new Shimano centerlock rotor with a very beatiful design
gravity
by gravity
105 di2 disc is what i look forward the most. Imagine a nice and slim hood..
Ritxis
by Ritxis
ooo wrote: ↑
Sat Apr 27, 2019 1:29 pm
That means, they take out the 1X cranks, with chainring alignment, to optimize the chain line..............???
ooo
by ooo
new 2x chain line standard, incompatible with everything else
