Ultegra chainrings....
TonyM
by TonyM
Hi,
Is it possible to use the Ultegra R8000 chainrings on a FC-R9100 Dura Ace crankset?
Is it possible to use a 34/46 combo for the R8000 instead of the 36/46 recommended combo?
alcatraz
by alcatraz
I believe they are compatible (although I haven't tried personally).
36/46 34/50 36/52 39/59 are all standard combinations. Sure a 10t difference should shift better than a 16t difference but shimano shifts so well that 16t difference works fine.
Ritxis
by Ritxis
Yes, is possible.....there's only one "Paste "............the aesthetics, the forms of cranks/chainrings do not exactly match
Ritxis
by Ritxis
Power can be, only the "subject" aesthetic
Smeagol
by Smeagol
It works but will look like this
wfcarrot
by wfcarrot
It can be, but you won't like it.
TonyM
by TonyM
Smeagol wrote:It works but will look like this
Ok I see the difference in the finish indeed!
TonyM
by TonyM
Thanks for the feedback guys!
I suppose I will stick with the DA chainrings for the DA crankset.
WorkonSunday
by WorkonSunday
yes, it can be done. both my wife's and my gravel bikes are using 46/34. mine is Ultegra 6800 and hers is R8000. just watch for small/small chain tension when you switch from 36 to 34.
In the house: Colnago V1r, Colnago A1r, Wilier Cento1 Air, Scott Scale 700SL, Bianchi FSE, Colnago Concept, Colnago A1r, Specialized Ruze Pro, Wilier GTR
trainergav
by trainergav
I ride an Ultegra 6800 46/34 on my gravel bike/commuter and it's fine. I have no issues shifting, altough it sometimes feels a bit rough when just pedaling. But that being said it's a bit of a frankenbike with mostly 6800 components but a rx clutch derailleur, shimano non series shifters and a non-series 11-34 cassette. My usual rule is to only pair like with like so I'm not surprised that things aren't perfect. I do find that the loss of 4 teeth is very noticiable when I am riding on the road however and I am frequently in the 46/11.
talltales
by talltales
Smeagol wrote:
Thu Apr 25, 2019 10:17 am
Is this not 6800 rings? I believe they look different from r8000.
biwa
by biwa
Was thinking to try the same thing, now think probably should stick to DA chainrings. Besides the look, I do wonder if there is any weight/material difference
