Rotor offset....
sfo423
by sfo423
F10 disc w/eTap and new wheels. I mounted up the rotors with a non-splined lockring. Went to mount the wheels and although the hub fits into the drops (thru axle) the rotors are ~30mm-40mm inboard of the calipers. This is the same on the front wheel (rotor way inboard). I have both calipers loose for adjustment.
If the spacing was wrong the hub width would not fit into the drops; right? I can't imaging the need to shim the rotor that much.
Stumped.
LeDuke
by LeDuke
Not familiar with those hubs, so:
Are the end caps removable, and on the wrong side of the hub?
wheelbuilder
by wheelbuilder
LeDuke wrote:
Thu Apr 25, 2019 1:35 am
-this- End caps reversed.
RedbullFiXX
by RedbullFiXX
Looks like your rotors are on backwards
Should be an arrow on your rotors for rotation direction
Cyclocross, in general, is about riding the wrong bike for the conditions.
wheelbuilder
by wheelbuilder
RedbullFiXX wrote:
Thu Apr 25, 2019 1:42 am
Good eye.
sfo423
by sfo423
Very good eye. Yup.
Should have stuck with Dura Ace!
wheelbuilder wrote:
Thu Apr 25, 2019 4:15 am
Good eye.
