Need help with Campy drivetrain
Noctiluxx
by Noctiluxx
My friend bought a used Pinarello F8 with Campy SR drivetrain. As you can see from the pic the chain is too short. I assume the original owner upgraded to an easier cassette and didn't bother replacing the rear derailleur to a longer cage. What is the best option? Buy a longer cage rear derailleur, add links to a the chain (or new) or compact crankset?
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
Alexandrumarian
by Alexandrumarian
More links, a longer cage will not make it look any better.
welchy
by welchy
Simples, longer chain bud. It looks like it would’ve been too short before anyway.
Miller
by Miller
Yes, more links or just install new chain of the correct length is the solution. You'd only install a compact if you want a compact.
Calnago
by Calnago
Is that a 29 or a 32 tooth cassette? If it’s a 29 then simply putting on a correct length chain is needed. With the correct length chain that setup will be good for any cassette from 11/23 to 11/29, with just a simple adjustment of the H screw to optimize it for the particular cassette being used, providing the chainrings stay the same. If it’s a 32 tooth cassette, then that derailleur is not designed for it, regardless of chain length.
