Handlebar replacement
osw000
by osw000
Hey,
I'm looking to replace my old non internal routing 3T Ergonova Team for a handlebar as light (190gr) with bit shorter reach (70mm) and that leaves the hoods a bit higher when ground level (= flatter transition ). Could be the Zipp's SL70 a candidate? Any other to consider?
Pinarello GAN 2016 - SRAM eTap - Alu wheels. 7,2kgs.
osw000
by osw000
Rephrasing the inquiry: do you Etap guys have a side picture of your short reach handlebars where I can appreciate a flat transition to the hoods?
Enviado desde mi SM-J530F mediante Tapatalk
Marin
by Marin
FSA compact? I really like the shape and the mild flare.
ArtV
by ArtV
ControlTech Tux Compact Carbon
125mm drop 75mm reach (actual)
161 grams (40mm)
Much less expensive than other boutique brands and available at fwbikes. I really like mine.
Art
Sent from my SM-T830 using Tapatalk
biwa
by biwa
Zipp's SL70 is a solid (non-carbon) choice. Or Parlee, 70mm reach and 128mm drop
osw000
by osw000
I will try a second hand SL70 in alu before spending money in carbon.
corky
by corky
Deda zero 100?
I have both Deda and Zipp 70SL ergo, the Deda are 75mm reach though and the Zipps have a little back sweep on the tops also the tops are flattened.
Both are great
