Gear ratios?
Campervan
by Campervan
Is there a website where I can see the difference of gear ratios? ie 52/36 with 11-30 and 50/34 with 11/32?
BMC Granfondo 02 105
Btwin 540
Specialized Venge Pro Disc
mattr
by mattr
mfuchs1
by mfuchs1
deleted
mattr
by mattr
shimmeD
by shimmeD
I'm using this one a lot :beerchug:
http://www.bikecalc.com/gear_ratios
Less is more.
RussellS
by RussellS
Am I the only one who just made his own gear chart using Excel? Mine tells speed too at whatever RPM I enter. As well as gear inches. I'm always comparing different cassette combinations with different chainring combinations to arrive at the perfect gearing!
mattr
by mattr
No. I did that before the internet was a thing as well.
Well. I wrote a program in basic to work it all out. Then did it again in lotus 123.
Really is no point now, as gear-calculator is easy to use and gives graphical inputs and outputs.
Gives speed at rpm as well.
