by Calnago on Fri Jul 26, 2019 11:25 pm
Well first of all, kudos to Trek, the first really large manufacturer to actually reverse track and move back to a threaded BB shell, even though it's gotta be more costly to manufacture. Good for us, and perhaps this will presuade other large manufacturers to follow suit. It only took how many years to finally acknowledge that maybe this threaded bottom bracket idea that had served us so well for like, forever, didn't really need to be changed so much after all. Simply make it bigger to accommodate larger BB shells, and voila... same as it ever was.
As far as I've been able to determine, here's what I can surmise thus far...
1) Trek's shell width will be 85.5mm, rather than the standard BB86 width of 86.5mm. This is so they can make the splines on the T47 BB deeper so it's not so finicky during the ham fisted mass production process.
2) Should work just fine with most cranks, even with standard T47 BB's being produced currently by other manufacturers, if the bearings can be located on the spindles in the proper location. Don't quote me on this, but I think other T47's (thinner flange) would work just fine for Shimano with no changes. In any case, worse case scenario is that you use the T47 BB of your choice, and just use a 0.5mm shim on either side of the shell in between it's face and the T47 flange.
3) Unfortunately, this wouldn't suffice for a Campy install, as Campy's bearings are pressfit onto the spindle and precisely located independently of where the cups are. However, I don't think it would be a difficult task to manufacture T47 cups to accommodate a Campy install. If Ceramic Speed did it for Colnago's T45 BB shell, whose volumes are miniscule compared to Trek, then I can't see why they woudn't be on this right away for Trek BB's as well. Chris King currently doesn't sell any of their BB's without bearings already in them, and as such they have no Campy solution, and I doubt that will change. They are pretty proud of their BB's, headsets, bearings, and the way they are all integrated, as well they should be. The beauty is that you could still use a Chris King T47 for most any of the other most popular cranks which don't have bearings pressed onto their spindles.
4) Wait and see if Trek carries this through their entire lineup, but now that I've seen one in a carbon shell, I don't see any reason why they wouldn't. So hell ya, Good on ya, Trek!
Calnago on Fri Jul 26, 2019 11:25 pm, edited 1 time in total.
