specialized road bikes - venge vs tarmac
GothicCastle
by GothicCastle
Previous generation Venge models just didn’t ride very well. They were aero-focused and not enough effort was put into ride characteristics. I wouldn’t have considered any of the previous models. I think this is the basis of people’s negative impression.
The latest gen, however, is quite different. Whatever they did, it is a far more comfortable day-to-day ride. Really nice overall, and surprising tire clearance. You can fit wide wheels/wide tires on the latest model, which is great for compliance.
The tarmac has always been a great ride. The venge will be marginally more aero, none of which matters for normal people, but that cable integration makes maintenance more of a pain in the ass. Contact points on the two should be almost identical, so fit shouldn’t be an issue.
If you like the aesthetics of the the venge, or if you want to go completely aero, go for it. Otherwise, the tarmac is such a great overall frame.
poppiholla
by poppiholla
So the Venge needs a spacer and then the stack height of the Tarmac and the Venge are the same. Ok but when you need more spacers to get the right fit, the Venge wil get a bigger spacer tower then the Tarmac. For me the look of a bike is also important and less spacers is more beautiful. Is my assumption correct?
I need on my Tarmac Sl6 size 58 3cm spacer to get the correct fit. That is the conical 20mm spacer and 1 extra 10mm spacer befor my stem (40mm) is mounted.
What do I need on a Venge disc size 58 to get the same fit as on my Tarmac? I assume that I need more spacers on the Venge but I am not sure. Who can help me out? Thanks.
CAAD8FRED
by CAAD8FRED
Geo between the Tarmac and Venge is identical. Weight is adjustable and Venge can be made to be as light as a Tarmac. So stiffness/weight of the dropouts is what separates climbing ability and comfort, right? Couldn’t the right set of wheels alleviate the issue?
ScottinFL
by ScottinFL
If you guys are watching the Tour of California (I've only now watched the first two stages on reply on NBC Gold app in Amazon Prime Video), it would seem that the Venge is the choice of the racers. Stage 1 was entirely flat, winner rides Venge to victory (no spoilers); and Stage 2 was entirely uphill for 5 hours, and winner rides Venge to victory (different rider, same bike).
That would seem to settle this dispute, no?
anykarthik
by anykarthik
poppiholla wrote:
Mon May 20, 2019 5:41 pm
The Venge does not need a "spacer". The headset topcap is taller on the Venge and makes up the difference. Also, the Venge frame has a notch for this topcap to fit into. So when it is in place, it doesn't stick out above the toptube as much. So aesthetics are not as adversely affected as you might think
Look at this image:
https://cdn.road.cc/sites/default/files ... k=XKtLL08G
anykarthik
by anykarthik
ScottinFL wrote:
Mon May 20, 2019 7:49 pm
The Tarmac wins plenty of stages (hint: it's the rider that matters). I think Sagan himself is on video saying he prefers the Tarmac. I can imagine mostly for comfort (which matters). FWIW, I have a Venge and only recently got to do a longish ride (4 hours). I run 28mm tires at 75psi and I was comfortable. I chose the Venge for mostly aesthetic reasons. That and the fact that here in Seattle, EVERYBODY has a Tarmac.
ScottinFL
by ScottinFL
If they have a choice, the racers are going to race the bike that gives them the best advantage. There is no reason why anyone with a choice b/w Venge and Tarmac would ride one vs. the other on an entirely uphill stage unless they believed that their choice gave them an advantage.
Now, that said, in that second stage, Sagan rode his Tarmac. So, he obviously prefers that bike for the uphill stages. But, he did not win the stage. In fact, he did not look so great on that stage. The winner, also on a factory supported Specialized team, chose to ride a Venge because he obviously prefers that bike -- and for good reason it seems.
I guess the point is that, for us mere mortals, it really does not matter one bit which of these two bikes you select. Go with whatever makes you happy to pull it out of the garage in morning :)
P.S. To my surprise, and lending even more support for my conclusion above (that it just doesn't matter anymore what you choose), the C'Dale SystemSix -- an overweight steed of a bike (apparently), seems to be doing just fine on the climbing stages.
dcorn
by dcorn
ScottinFL wrote:
Mon May 20, 2019 8:10 pm
Ha, I saw this and couldn't believe it either. That USA Cycling dude is killing it in the mountains on the SystemSix.
tabl10s
by tabl10s
TobinHatesYou wrote:
Wed Apr 17, 2019 5:26 pm
How tall are you? The difference in weight between the larger sizes is insignificant because the Tarmac’s tubes require more plies toward the center of each tube to retain strength and stiffness.
Take a look at this: https://youtu.be/PSuH8q3EraM?t=260s
His 61cm Tarmac Disc and Venge weigh pretty much exactly the same.
Could'a had a V8,... D'oh!... a Venge!
2015 Pinarello F8: 13.04lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 S-Works SL6 Ultralight: 11.04/5.007kg
2018 S-Works SL6: 12.04/5.625kg
tabl10s
by tabl10s
ryanw wrote:
Wed Apr 17, 2019 7:52 pm
SL6 on CLX50s and Aerofly II bars. Perfection.
I've got the 32's, 50's and 64's along with Meilenstein's. Can't wait to see they compare.
ichobi
by ichobi
Do get back to us! I really love my clx32 on the sl6.
pk1
by pk1
for what its worth, i ended up going for the venge but with CLX50s as i live in a hilly and windy area. just one ride so far but loved it. with the shallower wheels it feels just as responsive on climbs as the tarmac and also perfectly comfortable. perhaps most importantly, it looks amazing ;)
56cm weighs in right on 7Kg with dura-ace drive train, including pedals, cages, computer etc so while the tarmac would probably come in a bit lighter its not exactly an anchor
