4iiii viiiiva HR battery problem
petosagan
by petosagan
Hi.
Even if I change my batterie in my viiiiva, the indicator in the apps is about 25%.
Do you have an idea?
Thanks
Envoyé de mon SM-A530W en utilisant Tapatalk
alcatraz
by alcatraz
I think it has to do with the battery.
It's not necessarily that the battery has 25% capacity but the pwm thinks it's at 25% becauase of the voltage level and voltage drop.
I wouldn't bother changing. Just keep a spare with you and swap when it reports low battery. I don't even swap then. I swap when I get odd readings.
petosagan
by petosagan
Thank you
