S-Works Roubaix 2019 (2020) ?
Beancouter
by Beancouter
Does anyone know if the direct mount rear hanger for the venge / tarmac is compatible with the 2020 roubaix?
Part number S182600003
justonwo
by justonwo
I like FutureShock ok. I’m mostly ok when the roads are rough and don’t feel like I have to have some kind of damping, but it’s nice to have it when I want it. Usually, though, I keep it locked out. I don’t like that Specialized has to service it. I’ve had no end to the headaches with my Brain unit on my Epic. I’m on my 3rd Brain and the bike doesn’t even have 400 miles on it yet.
After 20 years of near-exclusivity with Specialized and multiple S-Works, I’m starting to move away from them. I really don’t like proprietary stuff that has to be sent in for service, and they aren’t the fastest on turnaround. Their direct-to-customer service is pretty meh as well. It’s not horrible, but it’s not great.
Still, my 2020 Roubaix has been reliable - apart for the issues with my SRAM drivetrain.
2020 S-Works Roubaix AXS Red (Zipp 303 NSW)
2020 Ultimate Evo 10.0 AXS Red (DT Swiss PRC-1100)
2020 Pinarello Dogma F12 AXS Red (Enve SES 3.4 Disc)
2006 Cervelo Soloist
2018 S-Works Camber
2019 S-Works Epic
Retired: 2014 S-Works Roubaix
CrankAddictsRich
by CrankAddictsRich
justonwo wrote:
Fri May 29, 2020 2:05 am
What bikes out there, doing similar things, don't have proprietary stuff? With the last few years, we've seen essentially all of the manufacturers move toward proprietary parts with special stems, bars, seatposts, etc... that's just the nature of the beast.
FlatlandClimber
by FlatlandClimber
CrankAddictsRich wrote:
Fri May 29, 2020 12:29 pm
Well, there are not that many proprietary parts you need to use on a Roubaix. On my Roubaix Team Edition I have a custom seatpost, a standard 3rd party stem and a standard 3rd party handlebar. It's not that bad, IMO.
Cervélo S5 Disc (2019) - 7.8kg
Open Cycles WI.DE (2019) - 8.5kg
Specialized Shiv TT Disc (2020) - 7.9kg
Specialized SW Roubaix Team (2020) - 7.3kg (successor — SOON —)
*all weights include pedals, computer mounts, and bottle cages.
justonwo
by justonwo
For sure. The difference here is that the parts need to be serviced and only Specialized can do the service. So it means a couple of weeks of downtime every service.
2018 S-Works Camber
2019 S-Works Epic
CrankAddictsRich
by CrankAddictsRich
Yea.. but that's not anything new, really... Lefty forks from cannondale have only been serviceable by Cannondale for like 10+ years I think... at least that's what I've been told.
I certainly understand the frustration, I just don't really think it is anything specific to Specialized. So many of the bikes within the last year or so have moved to proprietary setups... so you can't swap stems, bars, etc. That's across most brands.. Scott, Cannondale, BMC etc.
For sure this generation of Roubaix allows for universal things, but the next one probably won't, if it follows the lead of the Venge and tarmac.
Alexbn921
by Alexbn921
I've completely disassembled the futureshock 1.0 in my 2017 s works Roubaix. The overall design is very good with secondary safety redetection build in. It would take multiple internal failures for it to separate the stem from the fork. Maintenance consists of cleaning a well sealed system and relubing. As things wear out, it is imposable to adjust for play and should wear out as a system. Overall complexity and robustness of design are very good.
With that said, it’s complete bullshit that newer versions are not available and that Specialized locks all parts/service for the propriety part away from the end customer. Version 2.0 is much more complex and will need more service/attention. Having rebuild kits and parts available should be mandatory, but of course it’s not and even the techs at the shop don’t have access.
Anyway you will have to pry the futureshock from my cold dead hands. It’s that good at increasing my ride comfort and descending control. Having a previous wrist injuries makes me sensitive to the beat up roads where I live.
justonwo
by justonwo
Fri May 29, 2020 3:58 pm
It's not a huge deal if it's really only once a year or so. The situation with the Epic has been a bit frustrating with three failed Brain dampers, but I've been riding Specialized bikes for many years. They make great road bikes, no doubt. I was pretty happy with the damping on the 2014 Roubaix I had and don't feel like I need the FutureShock for most applications. I was more drawn to the improved aerodynamics and, of course, disc brakes. It's a great bike.
2018 S-Works Camber
2019 S-Works Epic
Beancouter
by Beancouter
1swiftvelo wrote:Here’s the part number.
This is the 2.0 not the 1.5 it says on the bag. The part number is the one from the S Works frameset.
It comes with the dial for the top and shim to use regular stem. That’s all.
Depending on the shop Retail is probably $500. Considered the old ones were $300 and this has a 500 hour life.
Jusy to confirm, Does the part number quotes come with everything to upgrade frkm 1.5 to 2.0?
Just ordered it but thought I had better check!!
Beancouter
by Beancouter
Not the sexiest bit of kit I have ever bought and eye wateringly expensive!!!
Also, not going to help the total build weight. Future Shock 2.0 at 351g
Beancouter
by Beancouter
Deleted
Beancouter
by Beancouter
7.22kg with a bit more weight to come off with new wheels and a few tweaks. Should be very close to 7kg.
Paint looks amazing - photos don’t do it justice
InconnuGlitterBoy
by InconnuGlitterBoy
Nice pictures! Love it.
The bottle cages, are they CarbonWorks? How are they to the bottles? I have some lightweight ones from Tune, but they scratch the bottles (Elite Fly) heavily.
Did you build the bike yourself?
Beancouter
by Beancouter
InconnuGlitterBoy wrote:Nice pictures! Love it.
Started out life as a comp Sagan edition which I stripped down to just the frameset, stem and seatpost. Added Di2 and wheels from my previous bike (Addict RC) and then bought the other bits and pieces to finish it off, including the FutureShock 2.0 unit.
Almost got caught out on availability of the key Di2 frame small parts, but managed to source some from Germany.
Whilst it’s not an s-works Frame, it is pretty much the same as the top of the range Sagan limited edition.
Only ridden around the block so far .... out at 7 tomorrow morning to find out whether I like it!!
