Direct Drive Trainer Question
Just look at it as if you’re running really fat tires. It’s all the rage now. So comfy.
Careful running your trainer over your beautiful light colored carpet. Bike chains have a tendency to throw off little bits of grease, crud, wax, etc. and once you get those inside your carpet, they aren't coming out. I like to put a big piece of cardboard under my trainer.
I use some of that interlockable rubber matting from the hardware stores under my neo from front to back
Never had issues with slip, and it catches the swimming pools I leave on the floor in sweat...
I use interlocking gym mats also, and put a trainer mat on top of them. It helps make my trainer sink in, preventing it from walking forward during sprint efforts. I have not noticed any loss in recorded power and the extra give is actually appreciated.
The short answer to your question is NO! But all the replies above still apply just the same as a bad idea for the reasons given already.CAAD8FRED wrote:Can a direct drive trainer sit on carpet or should it go on hardwood, granite, etc. I know I’ll need a mat for sweat and grime, but does the platform/surface matter to performance?
I had my KICKR on the floor in the garage, then a towel, then a soft rubber mat, and now with a soft rubber mat and a towel to catch the
The Herd
viewtopic.php?f=10&t=149524
Same here. I use the trainer mat as the gym tiles i have are pretty cheap and tear easily with cleats. Didn't want expensive stuff in the workshop as it gets all sorts of nasties on it, chain lube, DoT 5.1, mineral oil, brake cleaner, tubeless sealant, copper paste, grease, and i'm not expecting it to last, already got some holes melted in it. If i was walking on it with cleats, it'd already be fit for the bin.TobinHatesYou wrote: ↑Tue Apr 09, 2019 11:22 pmI use interlocking gym mats also, and put a trainer mat on top of them.
I put my trainer on carpet with 3 big floor tiles on top of a clear rolling office chair carpet cover on top of the carpet. The tiles are thick tiles, about the size of the trainer's body's footprint. The arms sit on their own tiles. Keeps the carpet clean and gives you some stability while reducing shocks on the bike frame.
- Similar Topics
- Replies
- Views
- Last post
- 3 Replies
- 415 Views
Last post by jimwhimpey
Tue Jul 09, 2019 5:53 pm
- 0 Replies
- 303 Views
Last post by wheelsONfire
Tue Feb 19, 2019 9:32 pm
- 19 Replies
- 2078 Views
Last post by R2power
Mon Apr 08, 2019 1:54 pm
- 3 Replies
- 234 Views
Last post by alcatraz
Fri Dec 13, 2019 1:11 am
- 1 Replies
- 524 Views
Last post by Jugi
Wed Mar 06, 2019 7:21 pm
