KMC X12 Chain on Campagnolo 12 speed 50 34
DaveS
by DaveS
To add something educational - every chain provides the opportunity to gather over 100 data points, if that's what you think is important. Use feeler gauges to measure the clearance between each pair of inner and outer plates. You'll quickly find that to be 0.1 to 0.2mm. Join the chain with the desired quick link, then check the side clearance. If it's in the same range, then it fits. It's not uncommon for a quick link to have slightly more clearance, even if the chain and quick link are the same model. If the clearance is more than 0.25mm, then the clearance is overly large, but it still doesn't mean that chain failure is imminent. More important is that the clearance not be too small. That could cause side stress that could break the end of a pin. Do not use a SRAM AXS link on a Campy chain, since it will have inadequate clearance.
The KMC 12 link is not nearly as good a fit as the SRAM eagle 12, to join a Campy chain, but I've used both with no problem.
When 11 speed first came out, I used Wipperman 10 links on my Campy chains for 2 years and never had a problem, despite the loose fit.
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
DaveS wrote:
Thu Mar 19, 2020 10:30 pm
The above is just uneducated drivel. You're trying to claim that any brand of product other than Campy is inferior, with no data points of your own to support your claim. I've used the SRAM eagle 12 link on four chains now, with no problem. If you want data points, use feeler gauges to check the side clearance between every inner and outer link on a Campy chain, then meaure the clearance at the connection with a SRAM eagle 12 link. You'll find it to be well within the variation between the other links. There's no reason for it not to work.
Thanks for that Dave S.
I have data points but can't share them. My position gives me access to the data on Campagnolo chains that you lack for any chain, other than that which you have generated for yourself from feeler guage measurement. As I pointed out, manufacturers very seldom, if ever, share data on dimensional tolerances and I have signed an NDA which prevents me from doing so, in the case of Campagnolo, for reasons of IP confidentiality.
I am not claiming superiority, if you read what I say - just that there are good reasons to distrust isolated examples of success or failure.
I'm sure in your time you have seen flukey measurements which taken in isolation might support, or give you reason to distrust, a hypothesis. I'd hope that you didn't place too much trust in them.
You have no idea what my technical or educational background are. You are probably making an assumption or assumptions. There's an old saw about that.
gloucester
by gloucester
Joining this discussion a little late but finding the views here informative and very helpful. Thank you.
I was also looking for a quick link solution for SR 12. If I understood correctly - but please correct me if I have anything wrong here:
- There isn't a quick link designed to work for 12 speed - some people have had some success with SRAM but others report KMC, Wipperman, etc catching on the sprockets in various ways
- Instead, you need to use Campy chain and split/rejoin this with joining pins every time if you want to take the chain off
- Campagnolo recommend splitting a 12 sp chain a maximum of 3 times before replacing
In other words, are we stuck with cleaning the chain on the bike? What about people who use wax?
DaveS
by DaveS
A SRAM eagle 12 link fits quite well with a Campy 12 chain. The KMC link doesn't fit as well.
I also use SRAM AXS chains with Campy 12.
rudye9mr
by rudye9mr
I thought this to be very helpul in understanding the topic and how the rivet placement helps as well as the park tool to use for campy
joeyb1000
by joeyb1000
gloucester wrote:
Fri May 01, 2020 5:02 pm
Do the initial cleaning before you put it on the first time, then acetone in a park tool.
Remove the jockey wheels. Put the crockpot on a stool under the bike. Dip/swish 1/2 the chain, then the other half. More time consuming, but you can clean & lube the jockey wheels at the same time. Next time I do it, I'll post a picture.
DaveS
by DaveS
Acetone is not the best degreasing solvent. Mineral spirits, white gas/naphtha all work better and less likely to damage decals or paint.
What's wrong with using the SRAM eagle 12 quick link? I take my chain off about once every 800km and clean it off the bike. I also swap to a different chain in my rotation.
carbonazza
by carbonazza
DaveS wrote:
Fri May 01, 2020 9:04 pm
... I take my chain off about once every 800km...
I use Eagle 12 quick links without problem too. Rotating with 3 waxed chains.
How did you arrive to 800km being the right moment to change? The noise?
I change them every 300km as a mindless habit.
And do you know some signal on when to replace the quick link?
DaveS
by DaveS
carbonazza wrote:
Fri May 01, 2020 11:52 pm
I don't hot wax. I use my own liquid wax lube, reapplied about every 200km, so there is never any noise. Chains do get dirty, so I alternate chains after 3 relubes.
joeyb1000
by joeyb1000
joeyb1000 wrote:
Fri May 01, 2020 8:49 pm
