Shimano ST-R9170/R9120/R8070/R8020 Hydraulic Brake Flange Connecting Bolt titanium
Klaster_1
by Klaster_1
Is this bolt available in titanium? I've checked titaniumplanet and ebay to no success. Anyone else interested in this? I messaged TP and will share their reply, is there's any.
Shimano ST-R9170/R9120/R8070/R8020 Hydraulic Brake Flange Connecting Bolt weight
by Nefarious86
If you're going aftermarket would alloy not make more sense?
Sent from my SM-G975F using Tapatalk
Using Tapatalk
Klaster_1
by Klaster_1
Nefarious86 wrote:
Sun Apr 07, 2019 7:04 am
Absolutely, but then I wonder why Shimano didn't make it in aluminium to begin with. Maybe it wouldn't be "hard" enough to crimp the olive?
mattr
by mattr
You're right, aluminium wouldn't be able to generate enough load/pressure to close the olive joint without either stripping, or gouging up the surface. They need a fair swing on them to do the job properly. (5-7Nm) Plus the load isn't all axial. Thin walled aluminium is not good at that!
Ti might have issues with galling against the brake lever body and the olive.
Plus, how much weight would you save on a safety critical part?
Ritxis
by Ritxis
mattr wrote:
Sun Apr 07, 2019 9:22 am
True, little weight saving without forgetting the cost of titanium
