Are We Getting A New Cannondale Supersix?
req110
by req110
I doubt it's possible. Holes are very very small. So you have to either route them externally through the two other holes there, or drill the internal holes bigger and risk damage.
by Nefarious86
What's the best Axle option for these at the moment ?
Sent from my SM-N976B using Tapatalk
Using Tapatalk
Dan Gerous
by Dan Gerous
Nefarious86 wrote:
Tue Oct 20, 2020 8:11 pm
The lightest AFAIK are the Robert Axle Project (I weighed mine at 62.4gr for the pair).
But the stock bolt-on Cannondale axles are pretty good too, just a few grams more (69.6gr for the pair with the O-rings so they they don't slide out of the hubs) but they keep the Speed-Release feature of only having to slide them by around an inch to take the wheels off, the RAP ones have to be removed completely before you can drop the wheels.
rmr40
by rmr40
My EVO 3 now updated with 35mm Feders/DT 240s EXP
6780g
Jackofallgrades
by Jackofallgrades
That's exactly the wheelset I've been eyeing up... They look good. Oh and review please! :smartass: :beerchug:
Cannondale SSEvo3 'Agaaaaaaaavé' - 7.5kg
...Work in Progress viewtopic.php?f=10&t=161634
rmr40
by rmr40
Jackofallgrades wrote:That's exactly the wheelset I've been eyeing up... They look good. Oh and review please! :smartass: :beerchug:
Too early to tell, only had a few rides round the block..stiffness seems good.. 1257g out the box, rear slightly out of true but nothing that can’t be sorted..the new EXP hubs are very loud! 5 weeks From Order to UK delivery..
ChiZ01
by ChiZ01
those are great price for dt240s exp wheelset, they must have sourced the hubs for dirt cheap
pmprego
by pmprego
rmr40 wrote:
Sun Oct 25, 2020 5:39 pm
6780g
I've just started looking at this bike... From the website the 105 version has the cables going inside the downtube but from your photo it goes inside the headtube. Is your frame not the "105 version"?
Thanks
req110
by req110
Mechanical cables go through down tube, unless you have some special conversion 3d printed 3rd party hack.
On the picture is bike on sram red etap, so he is handling only hydraulic hoses, not shifting.
Nicely looking bike.
pmprego
by pmprego
req110 wrote:
Thu Oct 29, 2020 5:15 pm
His bike makes total sense... yeah.
I got rushed because I saw a photo of one to sell that is running 105 (mechanical, of course) and has all the cables going through the headtube. No I wonder if it is some type of hack that you've mentioned.
I'll add another question... I've been searching the thread and I saw someone stating that a 51 size can only accomodate 71cm of BB-saddle height. Can people confirm this?
My saddle height is around 75cm but that is to the top of the saddle. I guess to the rails should be some 3cm less. Still above that 71 figure...
Hexsense
by Hexsense
pmprego wrote:
Thu Oct 29, 2020 5:32 pm
It should allow more.
My size 48 can already do 69cm with a low stack saddle (~2cm) and it is not close to the extension limit of the carbon seatpost.
Size 51 has 3.9cm longer seat tube. Just guesstimate it, you have 47.7cm seat tube. 330mm seatpost. Let assume almost 1/3 overlap where about 10cm of seatpost is in the seat tube.
That already put your seatpost end at 70.7cm with almost 1/3 of the seatpost inside the seat tube.
I guess alloy seatpost allow less extension (more seatpost must be inside the frame) than carbon one. That might explain the conservative number.
pmprego
by pmprego
Hexsense wrote:
Thu Oct 29, 2020 5:55 pm
Cool. Thanks!
I could have thought about that. I was clearly lazy. Thanks for the help
ingenieur
by ingenieur
You don't need a special conversion hack to put the cables inside downtube. I'm using sram red mechanical in my bike with the cables inside downtube.
Hexsense
by Hexsense
But then you run whole length housing, isn't it?
Most adapter allow you to stop the cable housing at the adapter piece. Just run bare cable to the bottom bracket.
pmprego
by pmprego
Hexsense wrote:
Thu Oct 29, 2020 10:56 pm
What adapter are you referring to?
